This is a modified version of the PurpleAir Local Driver originally written by @sidjohn1.
As with his driver:
[it] pulls Temperature, Humidity, Pressure, Dew Point, AQI, RSSI as well as PM1.0, PM2.5, PM10 an VOC particle reading directly from the device , no internet connection or cloud needed.
Devices with dual lasers both values will be averaged
I have modified it to implement retry logic with timeout handling. More details:
- Name changed to "PurpleAir AQI Local V2"
- httpGet changed from synchronous call to asynchronous call to reduce resource contention if there is a delay in the response.
- Added an option to retry the httpGet every 10 seconds if it fails. Default is 4 retries.
- Automatically limits retry count to 3 if update frequency is 1-minute; limits return count of 6 if update frequency is 2-minutes.
- Clarified that the "real time" parameter is 2 min average when off; real time when on.
- Set aqiMessage & aqiDisplay to "Error" if all retries fail.
- Dual sensor devices will report the AQI of the working sensor if one of the 2 sensors reports null. If both report null, it will return an AQI of "0" instead of null.
Marc
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* PurpleAir AQI Local
* Author: Sidney Johnson through version 1.4
* Marc Aronson & curson.com from v1.5 on.
* Date: 2024-06-03
* 1.0 - Initial Release
* 1.1 - Corrected pressure reporting to mBar
* 1.2 - Added aqiDisplay, for dual laser model rounded AQI to a whole number after averaging, formatting tweaks, added temp and humidity adjustments, changed aqimessage to aqiMessage.
* 1.3 - Added voc, vocDisplay and vocMessage. AQI Clean up.
* 1.4 - Code clean up and refactoring.
* 1.5 - Enhanced with asynchronous HTTP GET and retry logic with timeout handling. Set aqiMessage & aqiDisplay to "Error" if all retries fail.
* 1.6 - If one sensor returns NULL, AQI return the value of the other sensor. If both sensors return NULL, AQI returns 0 instead of NULL. Retry time reduced from 10 to 8 seconds.
import java.math.BigDecimal
metadata {
definition(name: "PurpleAir AQI Local with retry", namespace: "sidjohn1", author: "Sidney Johnson, Marc Aronson") {
capability "Temperature Measurement"
capability "Relative Humidity Measurement"
capability "Air Quality"
capability "Pressure Measurement"
capability "Signal Strength"
capability "Sensor"
capability "Polling"
attribute "pressure", "number" // Current pressure in Millibars
attribute "dewPoint", "number" // °F
attribute "aqi", "number" // AQI (0-500)
attribute "aqiDisplay", "string" // AQI + short danger level
attribute "aqiMessage", "string" // AQI danger level
attribute "pm01", "number" // µg/m³ - PM1.0 particle reading - current
attribute "pm25", "number" // µg/m³ - PM2.5 particle reading - current
attribute "pm10", "number" // µg/m³ - PM10 particle reading - current
attribute "voc", "number" // IAQ - Index for Air Quality (0-500)
attribute "vocDisplay", "string" // IAQ + short danger level
attribute "vocMessage", "string" // IAQ danger level
attribute "rssi", "string" // Signal Strength attribute
attribute "timestamp", "string" //
preferences {
section("URIs") {
input "ipAddress", "text", title: "Local IP Address", required: true
input name: "realTime", type: "bool", title: "off=2 min average, on=Real Time", defaultValue: false
input name: "updateMins", type: "enum", title: "Update frequency (minutes)", description: "Default: 5<br>Disabled: 0", defaultValue: '5', options: ['0', '1', '2', '5', '10', '15', '30'], required: true
input name: "retryCnt", type: "number", title: "Retry count", description: "Number of retry attempts if httpGet fails<br>Default: 4", range: "0..10", defaultValue: 5, displayDuringSetup: true, required: true
input name: "temperatureAdj", type: "number", title: "Temperature Calibration", description: "Adjust temperature up/down in °F [(-50)-(+50)]<br>Default: -8", range: "-50..50", defaultValue: -8, displayDuringSetup: true, required: true
input name: "humidityAdj", type: "number", title: "Humidity Calibration", description: "Adjust humidity up/down in percent [(-50)-(+50)]<br>Default: 4", range: "-50..50", defaultValue: 4, displayDuringSetup: true, required: true
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
def logsOff() {
log.warn "debug logging disabled..."
device.updateSetting("logEnable", [value: "false", type: "bool"])
def updated() {
unschedule()
log.info "Device updated..."
log.warn "debug logging is: ${logEnable}"
realTime = realTime ?: false
if (logEnable) runIn(1800, logsOff)
if (updateMins != "0") {
Random rand = new Random()
int randomSeconds = rand.nextInt(49)
schedule("${randomSeconds} */${updateMins} * ? * *", poll)
if (logEnable) log.debug(description)
def poll() {
if (logEnable) log.debug "Device polling..."
def url = "http://${ipAddress}/json?live=${realTime}"
if (logEnable) log.debug url
// Start the retry process with attempt 1
pollWithRetry(url, 1)
def pollWithRetry(url, attempt) {
retryCnt = [retryCnt, updateMins.toLong() * 3].min()
if (logEnable) log.debug "Attempt ${attempt} of ${retryCnt} for PurpleAir request"
def params = [
uri: url,
timeout: 9, // 9 second timeout
contentType: "application/json"
try {
asynchttpGet("handleHttpResponse", params, [attempt: attempt, url: url])
} catch (Exception e) {
log.error "Error occurred during asynchttpGet attempt ${attempt}: ${e.message}"
handleRetry(attempt, url, e.message)
def handleHttpResponse(response, data) {
def attempt = data.attempt
def url = data.url
if (logEnable) log.debug "HTTP Response received for attempt ${attempt}"
if (response?.status == 200) {
if (logEnable) log.debug "Successful response: ${response.getData()}"
try {
// Parse the JSON response data
def jsonData = response.getJson()
processResponse(jsonData)
log.error "Error parsing JSON response (attempt ${attempt}): ${e.message}"
handleRetry(attempt, url, "JSON Parse Error: ${e.message}")
} else {
log.error "Invalid response for PurpleAir request (attempt ${attempt}): ${response?.status} - ${response?.errorMessage}"
handleRetry(attempt, url, "HTTP ${response?.status}: ${response?.errorMessage}")
def handleRetry(attempt, url, errorMessage) {
if (attempt < retryCnt) {
def nextAttempt = attempt + 1
log.warn "PurpleAir request failed (attempt ${attempt}): ${errorMessage}. Retrying in 8 seconds..."
if (logEnable) log.debug "Scheduling retry attempt ${nextAttempt} in 8 seconds"
runIn(8, "retryPoll", [data: [url: url, attempt: nextAttempt]])
} else {
log.error "PurpleAir request failed after ${retryCnt} attempts. Last error: ${errorMessage}. Giving up."
sendEvent(name: 'aqiMessage', value: "Error - httpget failed")
sendEvent(name: 'aqiDisplay', value: "Error")
def retryPoll(data) {
def url = data.url
if (logEnable) log.debug "Executing retry attempt ${attempt}"
def processResponse(data) {
calibrateTempHum('temperature', data?.current_temp_f, settings.temperatureAdj, '°F', 'Temperature Calibrated')
calibrateTempHum('humidity', data?.current_humidity, settings.humidityAdj, '%', 'Humidity Calibrated')
sendEvent(name: 'dewPoint', value: data?.current_dewpoint_f, unit: '°F')
sendEvent(name: 'pressure', value: data?.pressure, unit: 'mBar')
processAQI(data)
processPM(data, 'pm01', 'pm1_0_atm', 'pm1_0_atm_b')
processPM(data, 'pm25', 'pm2_5_atm', 'pm2_5_atm_b')
processPM(data, 'pm10', 'pm10_0_atm', 'pm10_0_atm_b')
processVOC(data?.gas_680)
sendEvent(name: 'rssi', value: data?.rssi, unit: 'db')
sendEvent(name: 'timestamp', value: data?.DateTime, displayed: false)
def calibrateTempHum(name, value, adjustment, unit, logMessage) {
if (adjustment) {
def adjustedValue = (value.toInteger() + adjustment.toInteger())
sendEvent(name: name, value: adjustedValue, unit: unit)
if (logEnable) log.debug "${logMessage}: ${value} + ${adjustment} = ${adjustedValue}"
} else {
sendEvent(name: name, value: value, unit: unit)
def processAQI(data) {
def aqi = calculateAverage(data?."pm2.5_aqi", data?."pm2.5_aqi_b", 0)
sendEvent(name: 'aqi', value: aqi)
def (display, message) = getAQIMessage(aqi)
sendEvent(name: 'aqiDisplay', value: display)
sendEvent(name: 'aqiMessage', value: message)
def processPM(data, name, value1, value2) {
def pm = calculateAverage(data[value1], data[value2], 2)
sendEvent(name: name, value: pm, unit: 'µg/m³')
def processVOC(voc) {
if (voc) {
sendEvent(name: 'voc', value: voc)
def (display, message) = getVOCMessage(voc)
sendEvent(name: 'vocDisplay', value: display)
sendEvent(name: 'vocMessage', value: message)
} else if (logEnable) {
log.debug "VOC Not Detected"
def calculateAverage(value1, value2, scale) {
if (value1 && value2) {
return ((value1.toBigDecimal() + value2.toBigDecimal()) / 2.0).setScale(scale, BigDecimal.ROUND_HALF_UP)
} else if (value1) {
return value1.toBigDecimal().setScale(scale, BigDecimal.ROUND_HALF_UP)
} else if (value2) {
return value2.toBigDecimal().setScale(scale, BigDecimal.ROUND_HALF_UP)
return 0
def getAQIMessage(aqi) {
if (aqi < 51) {
return ["${aqi} - GOOD", "GOOD: little to no health risk"]
} else if (aqi < 101) {
return ["${aqi} - MODERATE", "MODERATE: slight risk for some people"]
} else if (aqi < 151) {
return ["${aqi} - UNHEALTHY", "UNHEALTHY: for sensitive groups"]
} else if (aqi < 201) {
return ["${aqi} - UNHEALTHY", "UNHEALTHY: for most people"]
} else if (aqi < 301) {
return ["${aqi} - VERY UNHEALTHY", "VERY UNHEALTHY: serious effects for everyone"]
} else if (aqi < 501) {
return ["${aqi} - HAZARDOUS", "HAZARDOUS: emergency conditions for everyone"]
return ["${aqi} - UNKNOWN", "UNKNOWN: invalid reading"]
def getVOCMessage(voc) {
if (voc < 51) {
return ["${voc} - EXCELLENT", "EXCELLENT: pure air, best for well-being"]
} else if (voc < 101) {
return ["${voc} - GOOD", "GOOD: no irritation or impact on well-being"]
} else if (voc < 151) {
return ["${voc} - LIGHTLY POLLUTED", "LIGHTLY POLLUTED: Ventilation suggested"]
} else if (voc < 201) {
return ["${voc} - MODERATELY POLLUTED", "MODERATELY POLLUTED: Ventilate with clean air"]
} else if (voc < 251) {
return ["${voc} - HEAVILY POLLUTED", "HEAVILY POLLUTED: Optimize ventilation"]
} else if (voc < 351) {
return ["${voc} - SEVERELY POLLUTED", "SEVERELY POLLUTED: Maximize ventilation & reduce attendance"]
} else if (voc < 501) {
return ["${voc} - EXTREMELY POLLUTED", "EXTREMELY POLLUTED: Maximize ventilation & avoid attendance"]
return ["${voc} - UNKNOWN", "UNKNOWN: invalid reading"]
