The HE Wiz driver uses local UDP communication only -- it does not talk to bulbs via their MQTT<->Cloud path, which the Wiz app uses. I do not know if these bulbs support the local-only protocol. However...
In the Wiz app settings under "Security Settings", check that "Allow Local Communication" is enabled. If it's not, enable it and see if it fixes the problem.
