[RELEASE] OwnTracks for Hubitat Presence Detection
CMD is turned on but i don't see the +follow in the Regions. Right now Regions is empty with just a + in the top right corner. How do I sync it?
Ahhh... In the "maintenance" tab on the main Hubitat OT app screen, you can select our device. On the next incoming location update it should pull back everything. That is probably what is causing you this unnecessary pain. :slight_smile:
So just select my phone then Done? Once I completed this should I see the +follow in the regions or do I have to add it?
Yes that is correct. +follow gets pushed from the Hubitat app.
Ok thanks, i tried it a few times even deleted the owntracks from my iphone reinstalled it then a sync in under maintenance to the phone still don't see +follow nor Home in either phone now in the regions. my region in the OT app is set for Home
Just so you know, @3rdStng forced me to make my post. That guy's just so pushy.. :wink:
@danabw @3rdStng you asked, you shall receive. I've update the first post with the new links. It is tagged "v2.7.1", which is 2.6.0-beta5 with the standard tweaks (those are listed in the post above as well).
Do you see any of your regions on the phone when you look? Feels like it didn't actually pull anything across.
I could not install this over your 2.5.10 version. Had to uninstall that version first. Just getting 2.7.1 configured now
No there is nothing even after re installing the app on the cell. Table is empty
I'm seeing the same thing.
I'm currently running 2.5.9. I don't really want to delete my existing app and have to re-configure everything again on my wifes and my phone.
@lpakula is there a way round this without having to delete and start again?
Many Thanks
It is not too bad. Just need the URL and the identifier you gave to the phone. Just got done updating the 4 in my household.
I could be wrong here, but doesn't exporting the config file include both the URL and the identifier automatically? Might save you from having to type them out manually?
Deleted the old but I cannot install the new .apk as my phone has advanced protection turned on. I've turned it off but it says it could take 24 hrs to go through. Aahhhh........
Does the .apk on playstore work OK does anybody know?
I've downloaded the playstore version and it does seem to be working. I'm just wondering what may not work or may be an issue going forward. Any thoughts @lpakula .
I've been using the play store version for a long time now without any issues.
I only asked because @danabw made me ask. Only then did I see the Greyhound bus.
But seriously, Thank you! Hopefully b5 just turns GA without any code changes.
Thanks for the confirmation. :+1:
I may drop my wifes phone onto the playstore version to keep us both aligned.
Thank you very much Lyle for sharing the bountiful beta update.
Obviously no good deed goes unpunished, cuz I'm in the same boat with the others on my Samsung ZFold 7 Android device, even with auto blocker turned off I can't install the update.
When prompted the first time I tried to install I skipped over the send to Play store options and just said install, and since then I don't get the options to send to Play store when I try again.
Curious how you got it installed, what magical steps did you use on your Android? :wink:
Is that happening when you click on the APK you downloaded in the My Files App? or when clicking a link somewhere?
If you downloaded an APK, then you should find it in the downloads section of the "My Files" samsung app. In order to install an APK from there, you need to go to Settings->Apps->My Files then scroll down to install unknown apps and toggle it on.
If you are trying to do the same from a browser (i.e. link), then you would have to do the same thing for that particlur app (chrome, firefox, etc).
If you originally clicked a link and then it was stopped, you might try checking the downloads section of my files. Most browsers automatically download the file to the downloads folder. If it is there, and you have done the above steps to install from unknown sources, all you should have to do is click on the APK file.
The only other thing I can think is that you bypassed the pop up to "continue" or "open in..." when using a link in a browser. For that, you can go to Settings-> Apps -> Google Play Store -> Set as Default (click it) and make sure that open supported links is turned on.
