[RELEASE] NodOn Zigbee drivers
Here are the Zigbee drivers I created for the NodOn Zigbee modules. All modules can be installed on a DIN Rail using the DIN Rail Box adapter.
NodOn is a French company specialized in Smart Home / Smart Building radio devices.
Supported devices (5)
NodOn Multifunction Relay Switch (SIN-4-1-20) NodOn Relay Switch with Metering (SIN-4-1-21) NodOn Lighting Relay Switch (SIN-4-2-20) NodOn Pilot Wire Heating Module (SIN-4-FP-21) NodOn Roller Shutter Relay Switch (SIN-4-RS-20)
Pairing instructions, features and supported firmwares for every device in the list above are documented here:
Installing
  • Using HPM: Search for the package named Hubitat drivers for NodOn smart devices (by Dan Danache). During install, you can select from the list only the drivers that you need. Later on, you can add more drivers using the "Modify" action in HPM.
  • Manual Install: Instructions and individual links for each driver are available in the Readme file (see above).
Have fun!
