Thank you for this code, it works my SOS 1 button fob flawlessly, The hole Hubitat community is amazing. If it wasn't for my Hubitat I couldn't live independently so thank you.
It's probably just me being a n00b but I can't get this to work without doing some things over several times. I have installed the driver and I can pair the device correctly. It selects the correct driver when paired. The device is listed as expected in the device list.
Then, nothing happens. When I click the buttons nothing appears in the device log. If I create simple automation rules to map actions to the buttons, the rules are never never triggered.
I eventually got it working by enabling debug logging, saving the configuration, then removing debug logging again (and saving). Now, after adding the device several times and messing with random settings, it works. But it all seems a little ... finicky. I was considering buying quite a few of these, and now I am having doubts.
What am I doing wrong? Is it because I have to wait for 5+ minutes after the device is added? Or do I just need to save the configuration 5-6 in a row? Or ... what?
I love the fact that you guys made this driver. It's very appreciated. I just can't quite grasp why pairing new devices isn't a simple and flawless process.
I have the modified version working; but with the mentioned difficulties adding devices. That might not be related to the driver, but no matter the reason it's stopping me from ordering 10-15 of these for various functions around the house.
Double-tap seems to work, which is good because 4 buttons really isn't a lot to work with...
After a rebuild of my Hubitat installation, and using the latest software on a C8, this driver unfortunately does not work any more. It produces the following error in the system log when any button is pressed:
java.lang.NullPointerException: Cannot invoke method next() on null object on line 95 (method parse)
