[RELEASE] Mitsubishi Heat Pump Hubitat Remote Sensor App (companion app)
I discovered that the SwiCago Heatpump library provides a remoteTemp command, which I figured had to be better than the matrix of Thermostat Controllers I had constructed to deal with inaccurate internal heat pump sensors.
I have a PR up against @interrobang's fine driver to add remoteTemp support, but if you'd like to use the feature now with Rule Machine or webCoRE (instead of the Remote Sensor app above), you can install it from my fork.
