No, I don't believe I made any changes that would impact that behavior. All I did was some code cleanup. This issue is what I was concerned about initially...that the increase/decrease button presses might not be discernable from the pushed/held presses of the other 4 buttons.
I am not actively working on adding any of my code to the Community Hubitat Package Manager. I do not personally use HPM, and most of my code is fairly mature and thus does not change very frequently. I also would hate for users to blindly upgrade the code via HPM, discover issues, and then have to deal with the fallout... I see the value in HPM, but I am just not overly eager to have to maintain yet another tool.
No, I'm referring to the + / - button between the bulb and socket buttons. It shows in the log that it's changing the level of the associated bulb but it doesn't actually affect the bulb itself.
So, the data is being collected and events are being fired. It is up to the user to determine how to use that data. @abuttino and @fabien.giuliano may be able to explain how they are using that data. It is not perfect, but it's something.
FYI I noticed that you have taken all the child devices off the beginning of this thread. Trying to install for a friend and there were no children getting made, had to use my drivers code from you to get him running.
Not sure what you’re referring to exactly. I haven’t removed anything. The Child Switch driver is linked in the ReadMe. I just verified that the link still works.
Thanks. I ended up just mirroring the device's level to the bulb1level attribute's level. If Bulb 1 changes to 90% then the Lamp's level changes to 90%. The granularity of the rocker switch being in 10% increments kind of sucks but it works well enough.
Just wanted to say, thank you for this brilliant Driver - I've been able to get it so that when my Doorbell is pressed the TV will automatically pause if watching TV (WebCoRE piston below for anyone interested):
Yep +1 from me too; really enjoying it. My Harmony Elite's four home buttons now let me turn on under couch sengled/zigbee lighting to walk through the theater in the dark, turn on/off sconces controlled by Lutron, shut the theater down and set a light path back to main living area by just the one power button press.
