[RELEASE] Levolor InMotion Blind/Shade control
This driver will control your Levolor InMotion blinds/shades. This is a pure local control (not cloud based)
There are a few requirements to use this; You must have the Levolor InMotion Hub…..the usb stick. Additionally with this, you do need to know the IP Address of the hub. I will not explain how to find that as that will vary from router to router.
You also need the Levolor App installed and you must be logged in (and have the shades/blinds already installed and connected to the app via the hub).
There is a 16 digit API Key you will obtain from the app. From the Levolor InMotion app, click the 3 lines in the top left corner. Go to “About”. Then click the Levolor InMotion logo 5 times quickly. A 16 digit Key will appear.
To install on Hubitat, you first need to install both the parent and child drivers. The code for both is below. To do this from go to the “Driver Code” in Hubitat, then “Add Driver”. Highlight the entire code of one of the drivers below, Copy and then Paste it in the New Driver area. Do not change the name. Just click save. Repeat this for both drivers.
Parent Driver:
Motion Blinds / Levolor InMotion Gateway Parent Driver
Protocol:
UDP 32100
Creates child devices:
Shade 1
Shade 2
Shade 9
Requires:
Gateway IP
AES Key
Author: Community
import hubitat.device.HubAction
import hubitat.device.Protocol
import groovy.json.JsonOutput
import groovy.json.JsonSlurper
metadata {
definition(
name: "Levolor InMotion Parent Device Gateway",
namespace: "Levolor InMotion",
author: "DN"
capability "Actuator"
command "discover"
command "refreshAll"
    attribute "token","string"
    attribute "status","string"
preferences {
    input(
        type:"text",
        title:"Motion Gateway IP Address",
        required:true
    input(
        type:"text",
        title:"Motion AES Key (16 characters)",
        required:true
    input(
        type:"bool",
        title:"Enable Debug Logging",
        defaultValue:true
def logDebug(msg){
if(debugEnable){
    log.debug "Motion Blinds: ${msg}"
INSTALL / INITIALIZE
def installed(){
logDebug "Installed"
def updated(){
logDebug "Updated"
DISCOVERY
def discover(){
def msg = [
    msgType:"GetDeviceList",
    msgID:getTimestamp()
sendUDP(msg)
REFRESH ALL CHILDREN
def refreshAll(){
logDebug "Refreshing all shade devices"
Integer count = 0
getChildDevices().each { child ->
    count++
    logDebug "Refreshing ${child.displayName}"
    child.refresh()
    // Prevent UDP flooding
    pauseExecution(500)
sendEvent(
    value:"Refreshed ${count} shades"
logDebug "Refresh all complete"
def push(){
logDebug "Dashboard Refresh button pushed"
refreshAll()
CREATE CHILD DEVICES
def createShadeChildren(deviceList){
Integer shadeNumber = 1
deviceList.each { device ->
    if(device.deviceType == "10000000"){
        String childId =
            device.mac
        def child =
            getChildDevice(childId)
        if(!child){
            child =
                addChildDevice(
                    "Levolor InMotion",
                    "Levolor InMotion Child Device",
                    childId,
                        label:
                            "Shade ${shadeNumber}",
                        isComponent:true
            logDebug(
                "Created Shade ${shadeNumber} ${childId}"
        state["shade${shadeNumber}"] =
            childId
        shadeNumber++
SEND CHILD COMMANDS
def sendShadeCommand(mac, data){
if(!state.token){
    logDebug "No token. Running discovery."
    discover()
    pauseExecution(1000)
def msg = [
    msgType:
        "WriteDevice",
    mac:
        mac,
    deviceType:
        "10000000",
    AccessToken:
        createAccessToken(),
    msgID:
        getTimestamp(),
    data:
        data
sendUDP(msg)
UDP SEND
def sendUDP(message){
String json =
    JsonOutput.toJson(message)
logDebug "UDP OUT ${json}"
try {
    def hubAction =
        new HubAction(
            json,
            Protocol.LAN,
            null,
                destinationAddress:
                    "${gatewayIP}:32100",
                type:
                    HubAction.Type.LAN_TYPE_UDPCLIENT
    sendHubCommand(
        hubAction
catch(Exception e){
    log.error(
        "UDP Send Error ${e}"
UDP RECEIVE
def parse(String description){
def msg =
    parseLanMessage(description)
if(!msg?.payload){
    return
String json
try {
    byte[] bytes =
        msg.payload.trim().decodeHex()
    json =
        new String(
            bytes,
            "UTF-8"
catch(Exception e){
    log.error(
        "Decode error ${e}"
    return
logDebug "RX ${json}"
def response
try {
    response =
        new JsonSlurper()
        .parseText(json)
catch(Exception e){
    log.error(
        "JSON error ${e}"
    return
Discovery Response
if(response.msgType ==
    "GetDeviceListAck"){
    state.token =
        response.token
    sendEvent(
        value:
            state.token
        response.data
Pass shade messages
    "WriteDeviceAck"){
    def child =
        getChildDevice(
            response.mac
    if(child){
        child.parseMotionResponse(
            response
AES TOKEN
def createAccessToken(){
if(!state.token){
    return null
try {
    javax.crypto.spec.SecretKeySpec key =
        new javax.crypto.spec.SecretKeySpec(
            aesKey.getBytes("UTF-8"),
            "AES"
    javax.crypto.Cipher cipher =
        javax.crypto.Cipher.getInstance(
            "AES/ECB/NoPadding"
    cipher.init(
        javax.crypto.Cipher.ENCRYPT_MODE,
        key
    byte[] encrypted =
        cipher.doFinal(
            state.token.getBytes("UTF-8")
    return encrypted
        .encodeHex()
        .toString()
        .toUpperCase()
catch(Exception e){
    log.error(
        "AES Error ${e}"
    return null
HELPERS
def getTimestamp(){
return new Date()
    .format(
        "yyyyMMddHHmmssSSS",
        TimeZone.getTimeZone("UTC")
Child Driver
Motion Blinds / Levolor InMotion Shade Child Driver
Child device driver
Names:
Shade 1
Shade 2
Protocol:
UDP 32100
Author: DN
metadata {
definition(
    name: "Levolor InMotion Child Device",
    author: "DN"
    capability "WindowShade"
    capability "Battery"
    command "stop"
    command "refresh"
    command "setPosition",
            type:"NUMBER",
            description:"0-100"
    attribute "position","number"
    attribute "voltage","number"
    attribute "rssi","number"
    attribute "shadeMAC","string"
    attribute "lastUpdate","string"
preferences {
    input(
        type:"bool",
        title:"Enable child debug logging?",
        defaultValue:true,
        required:false
INSTALL
def installed(){
sendEvent(
    value:
        device.deviceNetworkId
logDebug(
    "Installed ${device.displayName}"
COMMANDS
def open(){
logDebug(
    "OPEN command received"
parent.sendShadeCommand(
    device.deviceNetworkId,
        operation:1
startMovementRefresh()
def close(){
logDebug(
    "CLOSE command received"
        operation:0
def stop(){
logDebug(
    "STOP command received"
        operation:2
REFRESH
def refresh(){
logDebug(
    "REFRESH command received"
        operation:5
SET POSITION
def setPosition(position){
Integer target =
    position.toInteger()
if(target < 0){
    target = 0
if(target > 100){
    target = 100
logDebug(
    "SET POSITION ${target}%"
        targetPosition:target
MOVEMENT REFRESH CONTROL
After any movement command:
1 second refresh
then every 10 seconds
Total duration:
approximately 70 seconds
This allows time for long shade travel
while avoiding unnecessary polling forever.
def startMovementRefresh(){
logDebug(
    "Starting movement refresh cycle"
state.refreshCount = 0
unschedule(movementRefresh)
runIn(
    1,
    "movementRefresh"
def movementRefresh(){
    (state.refreshCount ?: 0) + 1
logDebug(
    "Movement refresh ${state.refreshCount}/8"
refresh()
Refresh timing:
1 second
11 seconds
21 seconds
31 seconds
41 seconds
51 seconds
61 seconds
71 seconds
Stops after final check.
if(state.refreshCount < 8){
    runIn(
        10,
        "movementRefresh"
else{
    logDebug(
        "Movement refresh cycle complete"
RESPONSE FROM PARENT
def parseMotionResponse(response){
logDebug(
    "RX DATA ${response.data}"
def data =
    response.data
if(!data){
    return
POSITION
Motion:
0 = open
100 = closed
Hubitat:
0 = open
100 = closed
No conversion required.
if(data.currentPosition != null){
    Integer position =
        data.currentPosition.toInteger()
    sendEvent(
        value:position
    sendEvent(
        value:
            position == 0 ? "open" :
            position == 100 ? "closed" :
            "partially open"
    logDebug(
        "Motion ${position}% -> Hubitat ${position}%"
BATTERY
Preserve existing calculation
Example:
802 = 8.02V
if(data.batteryLevel != null){
    BigDecimal volts =
        data.batteryLevel / 100.0
    sendEvent(
        value:
            Math.round(volts * 100) / 100.0
    Integer battery =
        calculateBattery(volts)
    sendEvent(
        value:battery
    logDebug(
        "Battery ${volts}V ${battery}%"
RSSI
if(data.RSSI != null){
    sendEvent(
        value:data.RSSI
sendEvent(
    value:new Date().toString()
BATTERY
Integer calculateBattery(BigDecimal volts){
Integer percent =
    Math.round(
        ((volts - 6.0) /
        (8.4 - 6.0))
        * 100
if(percent > 100){
    percent = 100
if(percent < 0){
    percent = 0
return percent
LOGGING
def logDebug(msg){
if(childDebugEnable == true){
    log.debug(
        "${device.displayName}: ${msg}"
Once both driver code are set, go to:
Device → Add Device → Virtual → Levolor InMotion Parent Device Gateway
Finish making this device like any other.
Once done, go in to that newly created device, go to the Preferences area, enter your IP address and the 16 digit key discovered from the Levolor InMotion app (include dashes). CLICK SAVE
Then go back to the commands tab. Click discover and then refresh.
You should now have child devices, one for each of your shades/blinds.
Thank you so much for this guide! I was able to get the blinds moving with my hub, but "Open" closes the blinds and "Close" opens the blinds. I've poked around at the code in effort to switch directions, but have been unsuccessful. Can you help shed some light on what I'm missing to reverse the open and close commands?
So there are 2 ways to address this.
The easy way: in the levor app, you can go into the setting of each blind and tell it to reverse direction.
The harder way(but maybe easier): re-work the driver code to have it flip flop.
If you copy and paste that entire driver code into Gemini AI and give it the prompt that the code wins but open ans closed are flip flopped it can generate you a new driver code with those flip flopped.
Hindsight I should have made an option in the setting to flip flop via HE settings.
I just looked and I can’t see in the app where you can reverse the blinds anymore.
Hmmm.
TBH, I don’t use open and close commands. I do % for all of them. And I never do 0 or 100. I do 1 and 99. It doesn’t stress the cords as much…..or so I want to think.
That's a good idea - use 100 and 0 instead of open and close. I am controlling roller shades which have their limits set where I would like for them to stop. I'll see what Gemini AI can do for me. Thank you again!
