I think I just had that burnout happen on one of my fan controllers. It only supports medium and high now.
That said you can make the driver always start the fan at 100%. One way, through Hubitat, requires using @jtp10181 's Universal Scanner Driver temporarily to make an adjustment to the fan controller's settings.
- Install the Universal Scanner Driver if you don't already have it. It's in Hubitat Package Manager, if you use that, otherwise manually install it.
- Go into your fan device page ->
Device Info - Change
TypetoZ-Wave Universal Scanner - Click
Save - Go to the
Commandstab - Under
Query Device, selectParametersand clickRun - When told to do so under
Current States, refresh the page - Go to the
Preferencestab - Set
Preset Levelto 99 and clickSave - Return to the
Device Infotab - Set
Typeback toLeviton ZW4SF Fan Controllerand clickSave
Going forward, the fan controller will always engage from off to on in high (99). You can change the speed after turning on the controller.
The other way is to update the Fan Controller's Preset Level through the fan controller itself using paddle press sequences. It's in the installation manual (available online if you no longer have the hard copy).
