[RELEASE] Kwikset Halo v2.0 - Possibly works with other Kwikset locks
First off, a quick shout to @mingaldrichgan and @MHedish @mingaldrichgan had a first version of this that worked, but it would only work for a week or two before tokens expired. With the help of @MHedish we got updated python and driver code working so that it seems you don’t need to update the tokens….ever? I have been running it for a few months now and it has not needed any updating.
I have tested this only with my own Kwikset Halo Touch. It is the WiFi model. This could/probably does work with other Kwikset locks….but likely DOES need the lock to be accessible via the Kwikset app.
There are 3 main sections of steps….first you have to make the device in Hubitat, second you have to use python/command prompt to generate tokens and lastly you have to enter those tokens into habitat. The entire process is quite easy…but is slightly more work than a normal device integration. If unfamiliar with python…..I wasn’t either before this project. If you get stuck, ask Gemini AI or hit me up with a DM.
Start
Copy the below code.
Kwikset Cloud Lock for Hubitat
Uses tokens initially generated by aiokwikset, then refreshes them directly
through AWS Cognito inside Hubitat.
Based on aiokwikset 0.7.3 protocol details.
import groovy.json.JsonOutput
import groovy.json.JsonSlurper
import groovy.transform.Field
metadata {
definition(
name: "Kwikset Cloud Lock",
namespace: "community",
author: "Marc and Drew"
capability "Actuator"
capability "Battery"
capability "Lock"
capability "Refresh"
capability "Initialize"
capability "Polling"
    attribute "connectionStatus", "enum", ["online", "offline", "authenticationRequired"]
    attribute "lastUpdated", "string"
    attribute "door", "enum", ["open", "closed", "unknown"]
    attribute "serialNumber", "string"
    attribute "firmwareVersion", "string"
    command "renewTokens"
    command "discoverDevice"
    command "setRefreshToken", [
        [name: "Refresh Token*", type: "STRING", description: "Paste full Kwikset Refresh Token"]
    command "setIdToken", [
        [name: "ID Token*", type: "STRING", description: "Paste full Kwikset ID Token"]
    command "setAccessToken", [
        [name: "Access Token*", type: "STRING", description: "Paste full Kwikset Access Token"]
preferences {
    input name: "kwiksetDeviceId", type: "text",
        title: "Kwikset Device ID", required: true
    input name: "kwiksetSerialNumber", type: "text",
        title: "Serial number (optional; discovered automatically)", required: false
    input name: "sourceFirstName", type: "text",
        title: "First name for lock history (optional)", required: false
    input name: "sourceLastName", type: "text",
        title: "Last name for lock history (optional)", required: false
    input name: "pollInterval", type: "enum",
        title: "Polling interval",
        options: ["1":"1 minute", "5":"5 minutes", "10":"10 minutes",
                  "15":"15 minutes", "30":"30 minutes", "60":"60 minutes"],
        defaultValue: "5", required: true
    input name: "logEnable", type: "bool",
        title: "Enable debug logging", defaultValue: true
    input name: "txtEnable", type: "bool",
        title: "Enable description-text logging", defaultValue: true
@Field static final String COGNITO_ENDPOINT =
"https://cognito-idp.us-east-1.amazonaws.com/"
@Field static final String COGNITO_CLIENT_ID =
"5eu1cdkjp1itd1fi7b91m6g79s"
@Field static final String API_BASE =
"https://ynk95r1v52.execute-api.us-east-1.amazonaws.com"
@Field static final String API_USER_AGENT = "okhttp/5.0.0-alpha.14"
@Field static final Integer TOKEN_SAFETY_SECONDS = 300
def installed() {
logInfo("Installed")
updated()
def updated() {
unschedule()
if (settings.kwiksetSerialNumber) {
    state.serialNumber = (settings.kwiksetSerialNumber as String).trim()
if (state.refreshToken && settings.kwiksetDeviceId) {
    schedulePolling()
    runIn(2, "initialize")
} else {
    log.warn "Set your tokens using the Device Commands section, and save your Kwikset Device ID in Preferences."
if (logEnable) {
    runIn(1800, "disableDebugLogging")
// Custom Token Commands
def setRefreshToken(String token) {
if (!token) {
log.error "No Refresh Token provided."
return
state.refreshToken = token.trim()
logInfo("Refresh Token updated successfully.")
checkAndInitialize()
def setIdToken(String token) {
if (!token) {
log.error "No ID Token provided."
return
state.idToken = token.trim()
logInfo("ID Token updated successfully.")
def setAccessToken(String token) {
if (!token) {
log.error "No Access Token provided."
return
state.accessToken = token.trim()
logInfo("Access Token updated successfully.")
private void checkAndInitialize() {
runIn(1, "initialize")
def initialize() {
try {
ensureAuthenticated()
discoverDevice()
refresh()
} catch (Exception e) {
handleFailure("Initialization", e)
def poll() {
refresh()
def refresh() {
logInfo("Executing refresh...")
try {
Map response = apiRequest(
"GET",
"/prod_v1/devices_v2/${urlEncode(settings.kwiksetDeviceId as String)}"
logDebug("Raw API Response: ${response}")
    Map deviceData = firstDataObject(response)
    if (!deviceData) {
        throw new RuntimeException("Kwikset returned no device data")
    updateFromDevice(deviceData)
    sendEvent(name: "connectionStatus", value: "online")
    sendEvent(name: "lastUpdated", value: formatTimestamp(new Date()))
    handleFailure("Refresh", e)
def discoverDevice() {
try {
    Map userResponse = apiRequest("GET", "/prod_v1/users/me")
    Map userData = firstDataObject(userResponse)
    if (userData) {
        state.firstName = settings.sourceFirstName ?: userData.firstname ?: ""
        state.lastName = settings.sourceLastName ?: userData.lastname ?: ""
    Map deviceResponse = apiRequest(
        "GET",
    Map deviceData = firstDataObject(deviceResponse)
    if (!deviceData) {
            "Device ID ${settings.kwiksetDeviceId} was not found"
        settings.kwiksetSerialNumber ?: deviceData.serialnumber
    if (!state.serialNumber) {
            "Device response did not contain serialnumber"
    sendEvent(name: "serialNumber", value: state.serialNumber)
    if (deviceData.devicename) {
        device.updateLabel(deviceData.devicename as String)
    logInfo("Discovered ${deviceData.devicename ?: settings.kwiksetDeviceId}")
    handleFailure("Device discovery", e)
def lock() {
executeLockAction("lock")
def unlock() {
executeLockAction("unlock")
private void executeLockAction(String action) {
try {
        discoverDevice()
        throw new RuntimeException("No serial number is available")
    String personName = (
        (settings.sourceFirstName ?: state.firstName ?: "") +
        (settings.sourceLastName ?: state.lastName ?: "")
    ).take(20)
    if (!personName) {
        personName = "Hubitat"
    Map payload = [
        action: action,
        source: JsonOutput.toJson([
            device: "apikwikset"
    apiRequest(
        "PATCH",
        "/prod_v1/devices/${urlEncode(state.serialNumber as String)}/status",
        payload
    sendEvent(
        value: action == "lock" ? "locking" : "unlocking",
        descriptionText: "${device.displayName} is ${action}ing"
    // Dual follow-up to capture delayed cloud updates
    runIn(4, "refresh")
    runIn(10, "refresh")
    handleFailure("${action.capitalize()} command", e)
def renewTokens() {
try {
refreshTokens()
logInfo("Kwikset tokens renewed")
handleFailure("Token renewal", e)
private void ensureAuthenticated() {
if (!state.refreshToken) {
sendEvent(name: "connectionStatus", value: "authenticationRequired")
throw new RuntimeException("A refresh token is required")
Long expiresAt = (state.tokenExpiresAt ?: 0L) as Long
Boolean missingIdToken = !state.idToken
Boolean expiringSoon =
    expiresAt == 0L ||
    now() >= expiresAt - (TOKEN_SAFETY_SECONDS * 1000L)
if (missingIdToken || expiringSoon) {
    refreshTokens()
private void refreshTokens() {
String refreshToken = state.refreshToken as String
if (!refreshToken) {
throw new RuntimeException("No refresh token is available")
Map body = [
    AuthFlow: "REFRESH_TOKEN_AUTH",
    ClientId: COGNITO_CLIENT_ID,
    AuthParameters: [
        REFRESH_TOKEN: refreshToken
Map params = [
    uri: COGNITO_ENDPOINT,
    headers: [
        "Content-Type": "application/x-amz-json-1.1",
        "X-Amz-Target":
            "AWSCognitoIdentityProviderService.InitiateAuth",
        "User-Agent":
            "aws-sdk-kotlin/1.3.81 ua/2.1 api/cognito-identity-provider#1.3.81"
    contentType: "application/json",
    requestContentType: "application/json",
    body: JsonOutput.toJson(body),
    timeout: 30
Map authenticationResult
httpPost(params) { response ->
    authenticationResult =
        response?.data?.AuthenticationResult as Map
if (!authenticationResult?.IdToken ||
    !authenticationResult?.AccessToken) {
        "Cognito refresh returned no ID/access token"
state.idToken = authenticationResult.IdToken
state.accessToken = authenticationResult.AccessToken
if (authenticationResult.RefreshToken) {
    state.refreshToken = authenticationResult.RefreshToken
Integer expiresIn =
    (authenticationResult.ExpiresIn ?: 3600) as Integer
state.tokenExpiresAt = now() + (expiresIn * 1000L)
logDebug("Token refresh succeeded; expires in ${expiresIn} seconds")
private Map apiRequest(
String method,
String path,
Map body = null,
Boolean retryAuthentication = true
ensureIdTokenPresent()
Map params = [
    uri: "${API_BASE}${path}",
    headers: [
        "Authorization": "Bearer ${state.idToken}",
        "User-Agent": API_USER_AGENT,
        "Accept-Encoding": "gzip",
        "Accept": "application/json"
    timeout: 30
if (body != null) {
    params.requestContentType = "application/json"
    params.body = JsonOutput.toJson(body)
try {
    Map result
    switch (method) {
        case "GET":
            httpGet(params) { response ->
                result = normalizeResponseData(response?.data)
            break
        case "PATCH":
            httpPatch(params) { response ->
            break
        case "POST":
            break
        default:
            throw new IllegalArgumentException(
                "Unsupported HTTP method ${method}"
    return result ?: [:]
} catch (groovyx.net.http.HttpResponseException e) {
    Integer status = e?.statusCode as Integer
    if (retryAuthentication && (status == 401 || status == 403)) {
        logDebug("API rejected token; renewing and retrying once")
        refreshTokens()
        return apiRequest(method, path, body, false)
    throw e
private void ensureIdTokenPresent() {
if (!state.idToken) {
refreshTokens()
private Map normalizeResponseData(Object data) {
if (data == null) {
return [:]
if (data instanceof Map) {
return data as Map
if (data instanceof String) {
Object parsed = new JsonSlurper().parseText(data as String)
return parsed instanceof Map ? parsed as Map : [data: parsed]
return [data: data]
private Map firstDataObject(Map response) {
Object data = response?.data
if (data instanceof List && !data.isEmpty() && data[0] instanceof Map) {
return data[0] as Map
return data as Map
return null
private void updateFromDevice(Map data) {
logDebug("Processing device payload: ${data}")
String lockValue = mapLockState(data)
logInfo("Lock status mapped to: ${lockValue}")
if (lockValue) {
    sendEvent(
        value: lockValue,
        descriptionText: "${device.displayName} is ${lockValue}"
Integer battery = parseInteger(
    firstNonNull(
        data.batterypercentage,
        data.batteryPercentage,
        data.battery
if (battery != null) {
    battery = Math.max(0, Math.min(100, battery))
    sendEvent(name: "battery", value: battery, unit: "%")
String doorValue = mapDoorState(data)
if (doorValue) {
    sendEvent(name: "door", value: doorValue)
Object serial = firstNonNull(data.serialnumber, data.serialNumber)
if (serial) {
    state.serialNumber = serial as String
    sendEvent(name: "serialNumber", value: serial as String)
Object firmware =
    firstNonNull(data.firmwareversion, data.firmwareVersion)
if (firmware) {
    sendEvent(name: "firmwareVersion", value: firmware as String)
private String mapLockState(Map data) {
Object raw = firstNonNull(
data.doorstatus,
data.doorStatus,
data.devicestatus,
data.deviceStatus,
data.lockstatus,
data.lockStatus,
data.alexahomelockstatus,
data.googlehomelockstatus
if (raw == null) {
return null
String value = raw.toString().trim().toLowerCase()
if (value in ["locked", "lock", "1", "true"]) {
    return "locked"
if (value in ["unlocked", "unlock", "0", "false"]) {
    return "unlocked"
if (value.contains("jam")) {
    return "unknown"
if (value.contains("unlock")) {
    return "unlocked"
if (value.contains("lock")) {
    return "locked"
return "unknown"
private String mapDoorState(Map data) {
// Halo model payloads map lock state to doorstatus;
// explicit open/close door contact sensors use doorposition
data.doorposition,
data.doorPosition
if (raw == null) {
return null
if (value in ["open", "opened", "1", "true"]) {
    return "open"
if (value in ["closed", "close", "0", "false"]) {
    return "closed"
return "unknown"
private Object firstNonNull(Object... values) {
for (Object value : values) {
if (value != null) {
return value
return null
private Integer parseInteger(Object value) {
if (value == null) {
return null
try {
if (value instanceof Number) {
return Math.round((value as Number).doubleValue()) as Integer
return Math.round(Double.parseDouble(value.toString())) as Integer
} catch (Exception ignored) {
return null
private void schedulePolling() {
Integer minutes = (settings.pollInterval ?: "5") as Integer
switch (minutes) {
case 1:
runEvery1Minute("poll")
break
case 5:
runEvery5Minutes("poll")
break
case 10:
runEvery10Minutes("poll")
break
case 15:
runEvery15Minutes("poll")
break
case 30:
runEvery30Minutes("poll")
break
case 60:
runEvery1Hour("poll")
break
default:
private String urlEncode(String value) {
return java.net.URLEncoder.encode(value, "UTF-8")
.replace("+", "%20")
private String formatTimestamp(Date date) {
return date.format(
"yyyy-MM-dd'T'HH:mm:ssXXX",
location?.timeZone ?: TimeZone.getTimeZone("UTC")
private void handleFailure(String operation, Exception e) {
String message = e?.message ?: e?.toString() ?: "Unknown error"
log.error "${operation} failed: ${message}"
if (message.toLowerCase().contains("notauthorized") ||
    message.toLowerCase().contains("refresh token") ||
    message.toLowerCase().contains("authentication")) {
    sendEvent(
} else {
    sendEvent(name: "connectionStatus", value: "offline")
def disableDebugLogging() {
log.warn "Debug logging disabled automatically"
device.updateSetting("logEnable", [value: "false", type: "bool"])
private void logDebug(String message) {
if (settings.logEnable) {
log.debug message
private void logInfo(String message) {
if (settings.txtEnable) {
log.info message
  1. In Hubitat, go to Drives Code on the left side, then click the “add driver” button.Once there, paste the code you copied above into the blank space and click save in top right.
  2. Go to Devices > Add Device > Virtual > Kwikset Cloud Lock > Next
  3. Finish the device add steps as you normally would.Then go to the device details>commands tab.
Now we move to capture the Tokens…….Before you continue, you need to have Python installed. If you don’t, just go to Download Python | Python.org and downloand and install the latest version of Python.
Once Python is installed follow these steps.
  1. Create a folder directly in your C drive called “KwiksetLock” so that it’s address is “C:\KwiksetLock”
  2. Copy the below code into a notepad and save it as “python kwikset_token_seed.py” and save that file in the previous created folder in C:\KwiksetLock
    import asyncio
    from getpass import getpass
    from aiokwikset import API
    async def main() -> None:
    email = input("Enter your Kwikset Email: ").strip()
    password = getpass("Enter your Kwikset Password: ")
    async with API() as api:
    print("Authenticating with Kwikset...")
    await api.async_login(email, password)
    print("\n--- TOKENS FOR HUBITAT ---")
    print(f"ID Token: {api.id_token}")
    print(f"Access Token: {api.access_token}")
    print(f"Refresh Token: {api.refresh_token}")
    user = await api.user.get_info()
    if user:
    print(
    f"User: {user.get('firstname', '')} "
    f"{user.get('lastname', '')}".strip()
    homes = await api.user.get_homes()
    for home in homes:
    print(
    f"\nHome Name: {home.get('homename')} | "
    f"Home ID: {home.get('homeid')}"
    devices = await api.device.get_devices(home["homeid"])
    for device in devices:
    print(
    f"Device Name: {device.get('devicename')} | "
    f"Device ID: {device.get('deviceid')} | "
    f"Serial Number: {device.get('serialnumber')}"
    print("--------------------------")
    if __name__ == "__main__":
    asyncio.run(main())
  3. Open Command prompt and type “cd C:\KwiksetLock”
  4. Type “pip install aiokwikset==0.7.3” and let it run.
  5. Type “python kwikset_token_seed.py”
  6. You will be prompted to enter your Kwikset email and password.This is the same info you use to log into the Kiwkset app.Note…when typing your password…it is a “blind” fill.It doesn’t show what you are typing.
If you did this correctly, you will get a message that starts with:
-----TOKENS FOR HUBITAT----
From there you will see: ID Token, Access Token and Refresh Token…and then at the bottom is some home info.
  1. Copy the ID Token (no extra data….and only copy the ID Token) and past that in the Hubitat device “Set ID Token” spot and click “set”.
  2. Repeat with the Access Token and the Refresh Token.
  3. In the habitat device now go to the Preferences Tab.
  4. Copy the “Device ID” from the end of the command prompt and paste that in the “Kwikset Device ID” spot in habitat.
  5. click the save button.
  6. Go back to the command tab and the information on the right side should be filled out and you can now test the commands.
