Ive added 3 lzw42 bulbs and they are not behaving properly. It takes up to 5 seconds for the 3 bulbs to recall a scene, when I make changes to the bulb on the driver page its status is not updating, and if I make a color bulb control on my dash it locks up. I added the bulbs on Sunday and the hubitat has the latest FW..
I tried using other drivers and the all behave basically the same
@cutler.bradley I have been working on fixing the inovelli bulb drivers... I have the multi-white running cleanly .. The multi-color is almost complete.. A couple bugs left to work out but they are working better than the inovelli provided drivers... I hope to have the multi-color bug free tomorrow...
After I work out the last few bugs in the multi-color I’ll try and get inovelli to merge my changes into the official driver
Hello guy/gals... I am the newest employee of Inovelli and will be helping @ericm with posts here. It will be a few weeks before I am caught up with the new RED product series, most likely after CES.
Any chance of getting a "for dummies" breakdown of how you do this? I've been banging my head on this of an on for a month now. Loaded up on your black Friday special, now I need to get these guys to do what I promised the Mrs they would do...
Looks like I have all the bugs worked out on the Bulb drivers .. LZW41 and LZW42.. If I don't see any bugs today or don't hear anyone report of bugs I will do a pull request to try and get them to merge into the official drivers..
- Added color pre-staging option
- Added power restored memory configuration
- Added debug logging configuration
- Fixed color setting (broken in official drivers)
- Fixed color temperature setting (broken in official drivers)
- Fixed reporting (broken in official drivers)
- Removed SmartThings related code
- Added importURL
Congratulations. This is great. You and Ericm, great combo. Looking forward to some fantastic drivers.
and 2.1.8 just dropped...so built in Inovelli drivers for the older series! YAY
Are the inovelli device drivers baked into 2.1.8 the same ones Inovelli made available?
If so, I assume that when updates are made to Inovelli's drivers, it will take a while for those to flow down to the built in driver?
And all the new ones except the Red dimmer, LZW31-SN (apparently they weren't given that device--guessing they may have been out of stock for a bit back then). But I'll still probably have to use a custom driver. As usual, Hubitat maxes out at double taps, and I want to use all five. Or at least the outer two or three where I can remember what they do.
No, they are Hubitat's take. Basically a fuller version of their existing Generic Z-Wave drivers with a few more options for these devices, plus the Set Indicator
custom command (an alternative to Inovelli's child devices) for the notification-capable LED devices.
I just really wanted this as I have a bunch and I'm trying to eliminate as many custom drivers/code as possible as I'm one of the people with a hub that eventually slows down and crashes. So the more things I can get that are baked in...the closer I get to calling support and letting them figure it out.
No, these are ground up HE drivers, not ports, not from Inovelli.
Hi, Scott. Glad to have additional support. 2 questions for you.
- am I better off using the built in Hubitat driver or should I stick w the Inovelli one?
- for the life of me I cannot get something set up and was hoping for help. I want to set up lights that when turned on at the switch have a custom dim level set by hub mode/time of day. Can you give me a idiots guide on how to do this??
Setup a button device, not a button, in Rule Machine. You can create rules for each button type. For the trigger select 'Button Device' in rule machine. You can then select the 'Prefill all button actions for ..' to create a template for all buttons or add them individually via 'Add a button action'.
Inovelli merged my LZW41/LZW42 driver changes into the official inovelli GitHub repository.. so if you were using my drivers you can go back to using the official ones...
@bcopeland I found the drivers from Inovelli. In the HE list of drivers there isn't anything for the bulbs. Are they going to put them in there? If they do put the drivers for the 41 and 42 in the list they need to label them as Ilumin.
Also, are the drivers on github any different from yours? Thanks
The drivers on inovelli's official GitHub is the exact same as mine except the namespace/name matches the original..
HE doesn't have official built-in drivers for these...
and I doubt HE will use my drivers if they officially add support... It seems HE prefers to build their official drivers from the ground up... I can't say I blame them as this keeps the qc and standards uniform...
Ok, thanks. I guess having a link in the driver to get newer updates would be good.
