[RELEASE] HundredGraphs - create Graphs and Alerts
HundredGraphs.com has finally got to the Hubitat. If you don't know, HundredGraphs is the service for logging and making graphs for Smart Homes. We mostly angled towards energy collection, however you can log and graph anything you want.
The basic FreeForever account is, duh, free.
However if you want to have longer retention or submit data with less than 10 mins interval between events, you would need a paid account.
To celebrate our new addition we would like to give you a discount.
If you are to get yearly subscription use hubitat12 as your code and you have almost 50% off. The number of discounts is limited though.
The installation is usual, you need to get plugin code from raw.githubusercontent.com/XLazz/ipstas-hubitat-hundredgraphs/master/smartapps/ipstas/hundredgraphs-logger.src/hundredgraphs-logger.groovy to Developer App code.
Create an User App.
Then you will need your own secret API key from your Hundredgraphs.com/profile profile
And then select what you would like to report.
It is still considered to be beta, but the code was ported from SmartThings where it works nicely.
And if anybody knows how I can do links I would really appreciate
The forum software (Discourse) won’t allow brand new users to post links or images as a spam-prevention measure. You’ll have to participate in the community a bit to gain the sufficient user privileges.
OK, let's see when I can be a trusted interlocutor. Meantime it either somebody reposts the accessible link or it is what it is.
UPD. Yee Haw! I went to trusted interlocuter level blazingly fast. Links are in.
So I've installed this and got it working alright, however a big problem I have with it is it only displays Hubitat "device names", not "device labels". As Hubitat only prompts you to change the device label when adding devices, not the name, many of my devices have the same name. The name is set by the device driver, and usually denotes the type of sensor it is, while the label is the real identifier for each sensor. Because of this, all the graphs generated in HundredGraphs have a meaningless legend by default:
I see that I could rename each sensor in HundredGraphs, or I know I could update all the names in hubitat (although I prefer for the name to show the type of sensor), but I have quite a few sensors, and it would be much easier if hundred graphs just pulled the device label! Ideally it should be able to pull both name and label, and I feel for most users, the label should be the primary identifier for the data, while the name should be a secondary attribute (sensor type)
Thanks for the report. We will definitely look into it. I agree, it has to be a label set by a user, not a generic device name
There is a new version on github (00.00.16), it should fix this issue
Is anyone using this? Is there a way that the graphs would show up on hubitat dashboard?
Yes, there are users with Hubitat plugin.
As for now you can see graphs only online. The hubitat hub itself is not powerful enough to run real-time graphs
Thank you for this. I am using the free version to monitor my home temperature and humidity.
Hi Stan, I am feeding thermostat operating state to Hundred Graphs. These are string values, not numeric, like "idle", "cooling", etc. Is there a way to translate these into numeric values, so I can graph them?
Right now, the values are feeding in as 0's and -1's.
Looks like the app is still in beta. I've requested access, so I can give this a try for tracking my temperature sensors.
Welcome to the community!
You could always try Quick Charts. No special access required. :wink:
Because I can't seem to get it to recognize my temperature sensors as a valid device to chart.
Jump over to the QC thread and we'll see if we can get you sorted.
