For the device code of hubitat, do you mean the drivers section? Because in devices section I only have the option to add new device in list or by brand… just wanted to be sure that its not in virtual device or something!
I'm really just trying to set this up so I can use SmartThings app in my phone as the presence sensor because the HE presence sensor doesn't work. (Even though it should and nobody seems to be able to figure out why it doesn't.)
A PAT is a Personal Access Token. PATs are required to access the SmartThingss API, which this integration requires. I"m not sure why that link isn't working at the moment, but you can get one by following this link;
Hey @bthrock thanks for this. It was enough to get me un-stuck. I managed to fumble my way through getting my "SmartThings iPhone" added into HE and it was available to update my rules. So with any luck next time I leave the house ST will trigger the HE rule. And hopefully when I return (within 30 minutes of sunset) another HE rule will trigger.
I copy the code to app for the main app and the Oauth app and I have enabled Oauth... then I have install the user app and give the ST key in the settings... But I cannot select any devices from ST to miror (empty list). I must forgot something... any idea? Thanks!
Working on the replica version with one major problem. The tv has several capabilities that are duplicated as custom (with different data definitions for the exact same attribute). I then receive two attribute updates, and one does not work with the rest of the system.
Is there a way to define a default device description that is not over-ridden by the app? Then I could delete the duplicate components. This would be similar to how rules are handled.
