[Release] HubDuino v1.1.9 - Hubitat to Arduino / ESP8266 / ESP32 / ThingShield Integration (ST_Anything)
Here is the Sketch that I'm using
//  File: ST_Anything_Multiples_EthernetW5500.ino
//  Authors: Dan G Ogorchock & Daniel J Ogorchock (Father and Son)
//  Summary:  This Arduino Sketch, along with the ST_Anything library and the revised SmartThings
//            library, demonstrates the ability of one Arduino + Ethernet W5500 Shield to
//            implement a multi input/output custom device for integration into SmartThings.
//            The ST_Anything library takes care of all of the work to schedule device updates
//            as well as all communications with the Ethernet W5500 Shield.
//            ST_Anything_Multiples implements the following ST Capabilities in multiples of 2 as a demo of what is possible with a single Arduino
//              - 2 x Door Control devices (used typically for Garage Doors - input pin (contact sensor) and output pin (relay switch)
//              - 2 x Contact Sensor devices (used to monitor magnetic door sensors)
//              - 2 x Switch devices (used to turn on a digital output (e.g. LED, relay, etc...)
//              - 2 x Water Sensor devices (using an analog input pin to measure voltage from a water detector baord)
//              - 2 x Illuminance Measurement devices (using a photoresitor attached to ananlog input)
//              - 2 x Voltage Measurement devices (using a photoresitor attached to ananlog input)
//              - 2 x Smoke Detector devices (using simple digital input)
//              - 2 x Carbon Monoxide Detector devices (using simple digital input)
//              - 2 x Motion devices (used to detect motion)
//              - 2 x Temperature Measurement devices (Temperature from DHT22 device)
//              - 2 x Humidity Measurement devices (Humidity from DHT22 device)
//              - 2 x Relay Switch devices (used to turn on a digital output for a set number of cycles And On/Off times (e.g.relay, etc...))
//              - 2 x Button devices (sends "pushed" if held for less than 1 second, else sends "held"
//              - 2 x Alarm devices - 1 siren only, 1 siren and strobe (using simple digital outputs)
//            During the development of this re-usable library, it became apparent that the
//            Arduino UNO R3's very limited 2K of SRAM was very limiting in the number of
//            devices that could be implemented simultaneously.  A tremendous amount of effort
//            has gone into reducing the SRAM usage, including siginificant improvements to
//            the SmartThings Arduino library.
//            Note: This sketch was fully tested on an Arduino MEGA 2560 using the Ethernet2 W5500 Shield.
//  Change History:
//    Date        Who            What
//    2015-01-03  Dan & Daniel   Original Creation
//    2017-02-12  Dan Ogorchock  Revised to use the new SMartThings v2.0 library
//    2017-04-16  Dan Ogorchock  New sketch to demonstrate multiple SmartThings Capabilties of each type
//    2017-04-22  Dan Ogorchock  Added Voltage, Carbon Monoxide, and Alarm with Strobe
//    2017-04-22  Dan Ogorchock  Initial version for W5500 Ethernet2 Shield
//    2018-02-09  Dan Ogorchock  Added support for Hubitat Elevation Hub
// SmartThings Library for Arduino Ethernet W5500 Shield
#include <SmartThingsEthernetW5500.h>    //Library to provide API to the SmartThings Ethernet W5500 Shield
// ST_Anything Library
#include <Constants.h>       //Constants.h is designed to be modified by the end user to adjust behavior of the ST_Anything library
#include <Device.h>          //Generic Device Class, inherited by Sensor and Executor classes
#include <Sensor.h>          //Generic Sensor Class, typically provides data to ST Cloud (e.g. Temperature, Motion, etc...)
#include <Executor.h>        //Generic Executor Class, typically receives data from ST Cloud (e.g. Switch)
#include <InterruptSensor.h> //Generic Interrupt "Sensor" Class, waits for change of state on digital input
#include <PollingSensor.h>   //Generic Polling "Sensor" Class, polls Arduino pins periodically
#include <Everything.h>      //Master Brain of ST_Anything library that ties everything together and performs ST Shield communications
#include <PS_Illuminance.h>  //Implements a Polling Sensor (PS) to measure light levels via a photo resistor on an analog input pin
#include <PS_Voltage.h>      //Implements a Polling Sensor (PS) to measure voltage on an analog input pin
#include <PS_TemperatureHumidity.h>  //Implements a Polling Sensor (PS) to measure Temperature and Humidity via DHT library
#include <PS_Water.h>        //Implements a Polling Sensor (PS) to measure presence of water (i.e. leak detector) on an analog input pin
#include <IS_Motion.h>       //Implements an Interrupt Sensor (IS) to detect motion via a PIR sensor on a digital input pin
#include <IS_Contact.h>      //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin
#include <IS_Smoke.h>        //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin
#include <IS_CarbonMonoxide.h> //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin
#include <IS_DoorControl.h>  //Implements an Interrupt Sensor (IS) and Executor to monitor the status of a digital input pin and control a digital output pin
#include <IS_Button.h>       //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin for button presses
#include <EX_Switch.h>       //Implements an Executor (EX) via a digital output to a relay
#include <EX_Alarm.h>        //Implements Executor (EX)as an Alarm capability with Siren and Strobe via digital outputs to relays
#include <S_TimedRelay.h>    //Implements a Sensor to control a digital output pin with timing/cycle repeat capabilities
//Define which Arduino Pins will be used for each device
//  Notes: Arduino communicates with both the W5500 and SD card using the SPI bus (through the ICSP header).
//         This is on digital pins 10, 11, 12, and 13 on the Uno and pins 50, 51, and 52 on the Mega.
//         On both boards, pin 10 is used to select the W5500 and pin 4 for the SD card.
//         These pins cannot be used for general I/O. On the Mega, the hardware SS pin, 53,
//         is not used to select either the W5500 or the SD card, but it must be kept as an output
//         or the SPI interface won't work.
//         See https://www.arduino.cc/en/Main/ArduinoEthernetShield for details on the W5500 Sield
//"RESERVED" pins for W5500 Ethernet Shield - best to avoid
#define PIN_4_RESERVED            4   //reserved by W5500 Shield on both UNO and MEGA
#define PIN_1O_RESERVED           10  //reserved by W5500 Shield on both UNO and MEGA
#define PIN_11_RESERVED           11  //reserved by W5500 Shield on UNO
#define PIN_12_RESERVED           12  //reserved by W5500 Shield on UNO
#define PIN_13_RESERVED           13  //reserved by W5500 Shield on UNO
#define PIN_50_RESERVED           50  //reserved by W5500 Shield on MEGA
#define PIN_51_RESERVED           51  //reserved by W5500 Shield on MEGA
#define PIN_52_RESERVED           52  //reserved by W5500 Shield on MEGA
#define PIN_53_RESERVED           53  //reserved by W5500 Shield on MEGA
//Digital Pins
//Digital Pins
#define PIN_SWITCH_1              22  //Living Room Speakers
#define PIN_SWITCH_2              23  //Kitchen Speakers
#define PIN_SWITCH_3              24  //Kids Bedroom Speakers
#define PIN_SWITCH_4              25  //Master Bedroom Speakers
#define PIN_SWITCH_5              26  //Master Bathroom Speakers
#define PIN_SWITCH_6              27  //Source1 switch to Source2
//#define PIN_SWITCH_7              40  //SmartThings Capability "Switch"
//---Begin Push Button declarations---
#define MAX_PUSHBUTTONS 6
#define MIN_DEBOUNCE_TIME 50 //push-buttons must be held for 50ms to prevent chattering input
#define PIN_BUTTON1   30
#define PIN_BUTTON2   31
#define PIN_BUTTON3   32
#define PIN_BUTTON4   33
#define PIN_BUTTON5   34
#define PIN_BUTTON6   35
byte nBtnIndex;      //Index Variable
bool nCurrentVal;     //temp variable
String strCommand;
byte nBtnVals[MAX_PUSHBUTTONS][2];   //Array of current[0] and last[1] values of the pushbuttons
byte nBtnPins[MAX_PUSHBUTTONS] = {PIN_BUTTON1, PIN_BUTTON2, PIN_BUTTON3, PIN_BUTTON4, PIN_BUTTON5, PIN_BUTTON6};
unsigned long lngBtnLastMillis[MAX_PUSHBUTTONS]; //needed to properly debounce the pushbutton inputs
st::EX_Switch* swArray[MAX_PUSHBUTTONS]; //need an array of the executors so we can togle the correct one
//---End Push Button declarations---
//W5500 Ethernet Shield Information
byte mac[] = {0x2C, 0xF7, 0xF1, 0x08, 0x0C, 0x38}; //MAC address                                 //  <---You must edit this line using the MAC address provided with your W5500 Shield!
IPAddress ip(192, 168, 1, 221);               //Arduino device IP Address                   //  <---You must edit this line!
IPAddress gateway(192, 168, 1, 1);            //router gateway                              //  <---You must edit this line!
IPAddress subnet(255, 255, 255, 0);           //LAN subnet mask                             //  <---You must edit this line!
IPAddress dnsserver(192, 168, 1, 1);          //DNS server                                  //  <---You must edit this line!
const unsigned int serverPort = 8090;         // port to run the http server on
// Smartthings / Hubitat Hub TCP/IP Address
IPAddress hubIp(192, 168, 1, 226);    // smartthings/hubitat hub ip //  <---You must edit this line!
// SmartThings / Hubitat Hub TCP/IP Address: UNCOMMENT line that corresponds to your hub, COMMENT the other
//const unsigned int hubPort = 39500;   // smartthings hub port
const unsigned int hubPort = 39501;   // hubitat hub port
//st::Everything::callOnMsgSend() optional callback routine.  This is a sniffer to monitor
//    data being sent to ST.  This allows a user to act on data changes locally within the
//    Arduino sktech withotu having to rely on the ST Cloud for time-critical tasks.
void callback(const String &msg)
  //Uncomment if it weould be desirable to using this function
  //Serial.print(F("ST_Anything_Miltiples Callback: Sniffed data = "));
  //Serial.println(msg);
  //TODO:  Add local logic here to take action when a device's value/state is changed
  //Masquerade as the ThingShield to send data to the Arduino, as if from the ST Cloud (uncomment and edit following line(s) as you see fit)
  //st::receiveSmartString("Put your command here!");  //use same strings that the Device Handler would send
//Arduino Setup() routine
void setup()
  //Declare each Device that is attached to the Arduino
  //  Notes: - For each device, there is typically a corresponding "tile" defined in your
  //           SmartThings Device Hanlder Groovy code, except when using new COMPOSITE Device Handler
  //         - For details on each device's constructor arguments below, please refer to the
  //           corresponding header (.h) and program (.cpp) files.
  //         - The name assigned to each device (1st argument below) must match the Groovy
  //           Device Handler names.  (Note: "temphumid" below is the exception to this rule
  //           as the DHT sensors produce both "temperature" and "humidity".  Data from that
  //           particular sensor is sent to the ST Hub in two separate updates, one for
  //           "temperature" and one for "humidity")
  //         - The new Composite Device Handler is comprised of a Parent DH and various Child
  //           DH's.  The names used below MUST not be changed for the Automatic Creation of
  //           child devices to work properly.  Simply increment the number by +1 for each duplicate
  //           device (e.g. contact1, contact2, contact3, etc...)  You can rename the Child Devices
  //           to match your specific use case in the ST Phone Application.
  //Executors
  static st::EX_Switch              executor1(F("switch1"), PIN_SWITCH_1, LOW, true);
  static st::EX_Switch              executor2(F("switch2"), PIN_SWITCH_2, LOW, true);
  static st::EX_Switch              executor3(F("switch3"), PIN_SWITCH_3, LOW, true);
  static st::EX_Switch              executor4(F("switch4"), PIN_SWITCH_4, LOW, true);
  static st::EX_Switch              executor5(F("switch5"), PIN_SWITCH_5, LOW, true);
  static st::EX_Switch              executor6(F("switch6"), PIN_SWITCH_6, LOW, true);
  // static st::EX_Switch              executor7(F("switch7"), PIN_SWITCH_7, LOW, true);
  //  Configure debug print output from each main class
  st::Everything::debug = true;
  st::Executor::debug = true;
  st::Device::debug = true;
  st::PollingSensor::debug = true;
  st::InterruptSensor::debug = true;
  //Initialize the "Everything" Class
  //Initialize the optional local callback routine (safe to comment out if not desired)
  st::Everything::callOnMsgSend = callback;
  //Create the SmartThings EthernetW5500 Communications Object
  //STATIC IP Assignment - Recommended
  st::Everything::SmartThing = new st::SmartThingsEthernetW5500(mac, ip, gateway, subnet, dnsserver, serverPort, hubIp, hubPort, st::receiveSmartString);
  //DHCP IP Assigment - Must set your router's DHCP server to provice a static IP address for this device's MAC address
  //st::Everything::SmartThing = new st::SmartThingsEthernetW5500(mac, serverPort, hubIp, hubPort, st::receiveSmartString);
  //Run the Everything class' init() routine which establishes Ethernet communications with the SmartThings Hub
  st::Everything::init();
  //Add each sensor to the "Everything" Class
  //Add each executor to the "Everything" Class
  st::Everything::addExecutor(&executor1);
  st::Everything::addExecutor(&executor2);
  st::Everything::addExecutor(&executor3);
  st::Everything::addExecutor(&executor4);
  st::Everything::addExecutor(&executor5);
  st::Everything::addExecutor(&executor6);
  //  st::Everything::addExecutor(&executor7);
  //Initialize each of the devices which were added to the Everything Class
  st::Everything::initDevices();
  //Add User Customized Setup Code Here (instead of modifying standard library files)
  //---Begin Push Button initialization section---
  swArray[0] = &executor1;
  swArray[1] = &executor2;
  swArray[2] = &executor3;
  swArray[3] = &executor4;
  swArray[4] = &executor5;
  swArray[5] = &executor6;
  //Allocate strCommand buffer one time to prevent Heap Fragmentation.
  strCommand.reserve(20);
  //Configure input pins for hardwired pusbuttons AND read initial values
  for (nBtnIndex = 0; nBtnIndex < MAX_PUSHBUTTONS; nBtnIndex++) {
    pinMode(nBtnPins[nBtnIndex], INPUT_PULLUP);
    nBtnVals[nBtnIndex][0] = digitalRead(nBtnPins[nBtnIndex]);   // read the input pin
    nBtnVals[nBtnIndex][1] = nBtnVals[nBtnIndex][0];
    lngBtnLastMillis[nBtnIndex] = 0;  //initialize times to zero
  //---End Push Button initialization section---
//Arduino Loop() routine
void loop()
  //Execute the Everything run method which takes care of "Everything"
  st::Everything::run();
  //Add User Customized Loop Code Here (instead of modifying standard library files)
  //---Begin Push Button execution section---
  //Loop through the pushbutton array
    nCurrentVal = digitalRead(nBtnPins[nBtnIndex]); // read the input pin
    if (nCurrentVal != nBtnVals[nBtnIndex][1])      // only act if the button changed state
      lngBtnLastMillis[nBtnIndex] = millis();  //keep track of when the button changed state
    if ((millis() - lngBtnLastMillis[nBtnIndex] >= MIN_DEBOUNCE_TIME) && (nBtnVals[nBtnIndex][0] != nCurrentVal))
      nBtnVals[nBtnIndex][0] = nCurrentVal; //keep current value for proper debounce logic
      if (nCurrentVal == LOW)    //only care if the button is pressed (change LOW to HIGH if logic reversed)
        strCommand = swArray[nBtnIndex]->getName() + " " + (swArray[nBtnIndex]->getStatus() == HIGH ? "off" : "on");
        Serial.print(F("Pushbutton: "));
        Serial.println(strCommand);
        swArray[nBtnIndex]->beSmart(strCommand);  //Call the beSmart function of the proper executor object to either turn on or off the relay
        strCommand.remove(0); //clear the strCommand buffer
    nBtnVals[nBtnIndex][1] = nCurrentVal;  //keep last value for proper debounce logic
  //---End Push Button execution section---
I see you chose to use the STATIC TCP/IP address assignment in the sketch (which is what I typically recommend!) As such, you have the possibility for a duplicate IP address conflict on your home network. Might this be the issue? Unplug the Arduino from power, and try ping 192.168.1.221 to see if there is another device on your home network using the same address. That would help to explain the behavior you're seeing.
OH - one more thing... I no longer the W5500 specific library with the current Arduino code. There is now a generic Ethernet library from Arduino for all W5x00 series shields. Perhaps this is the issue?
Try upgrading all of your ST_Anything Arduino libraries to my latest and greatest versions from my GitHub repository.
Take a look at ST_Anything/ST_Anything_Multiples_EthernetW5x00_MEGA.ino at master · DanielOgorchock/ST_Anything · GitHub as an example. Note the change to the include file for the SmartThings... communications library.
no issue with ping. When plugged 100% success and when its not 100.0% packet loss
--- 192.168.1.221 ping statistics ---
10 packets transmitted, 0 packets received, 100.0% packet loss
Dan,
I have updated per your recommendation and added my portion for Push Button section to the new code. Now it works. thank you so much.
moving on the the next migration from ST to Hubitat.
Thank you
Quick Question in Hubitat what is the difference between device name and device Label? which one will show up in Alexa of on the dashboard? Thank you
If a Label is defined, it will usually be what is displayed in all Apps and the Device List.
I have, my arduino skills are limited but I’ve got a very crude Air Quality monitor running on an WIO Terminal with a BME680 sensor using the BSEC library. A lot of hard coding and an annoying bug that causes it to stop publishing to MQTT after a few days that I’ve not ironed out. I push the measurements to grafana.
I’d be happy to share the code if anyone fancies picking it up and helping to tidy up
So I think that i'm far from router...my rssi is 87 .... so I think it doesn't always get the message.
A couple questions.... anyone had luck adding an antenna to a nodemcu ?
I assume that the messaging is open loop right? send the message and if it doesn't make it you don't know. ....is that right? If so, any thought of making it closed loop.... i.e. arduino sends the message X and waits for an ack for message X, if not sends again.
Thanks for the really cool code ..having lots of fun !!
tim
Yes, that is a pretty weak signal.
I have never tried to. I have 4 Ubiquiti UniFi Wireless Access Points in my house, so WiFi coverage is no longer an issue.
Messaging uses fairly normal http data tranfers. There is no 'store and forward' mechanism, and no guaranteed delivery. The ST_Anything Arduino library does send status updates to the hub every 5 minutes, even if nothing has changed. This is to help to ensure that the Hubitat hub always has recent data.
It would not be practical to try and add a 'store and forward' messaging architecture due to the limited memory size on many microcontrollers.
Well, my load cell project is progressing. I've got the mounting cradle built and the units wired up.
IMG_6149
IMG_6150
I'm having a tough time getting the amplifiers calibrated. If I get the zeros done correctly I run out range at the top end - so not getting a full 5 volts out at 20 kg. I had to change out one of the load cells as it was outputting even with no load. Don't whether it's because I'm running them at the lower supply voltage of 12v instead of 24 or if the electronics is not up to scratch. One board seems easier to get close than the other.
Conditioner
Anyway, got it all roughly working and set it up in the pool shed.
IMG_6152
I'm now plagued with constantly varying voltage readings reported back to my child device. I've got one drum full and the other virtually empty but my readings are all over the place.
Guess tomorrow I'll hook up a multimeter at the Mega and see whether the fluctuations are from the cell amplifiers or there's something else going on.
Hopefully it'll be worth all the work!!
graphs
I have a relay that turns on a pet feeder motor and I want it to automatically turn off after a set number of milliseconds. I see the TimedRelayPair which looks close however mine is simply a single relay that while closed the motor runs then when open the motor stops.
Can I still use this Driver type or do I need to use something else? Currently I'm using switch but it has no option to turn off automatically and the least amount of delay in Rule Machine I see is 1 second (which is ok but a little more than my cat needs per meal) and every once in a while the Hubduino doesn't update it's state immediately so sometimes it can take a few seconds to stop running which then can overfill the bowl, so I was hoping for an auto off handled by the on ESP8622 via the on command specifying how long it runs, which is what looks like is happening with the TimedRalayPair type although I may be wrong on that.
Thanks.
Use the singleton S_TimedRelay device. There is an example of it in the ST_Anything_Multiples_ESP8266WiFi.ino example sketch.
The timed relay pair device was created to operate a valve that used one output to turn on, and another output to turn off.
Hi, I'm using several devices in a sketch, with one of them being the PulseCounter
The Pulse counter frequency to send updates is set to 60 seconds.
For some reason, there are occasions, where it sends updates at under 60.. and in some cases the 2 odd intervals add up to near 60....this is not always the case... see pic. Is there any reason for this?
Yes, their may indeed be an explanation for this. I never considered the implication of the every five minute automatic refresh of all sensor data. If you look at your data, you'll see the issue occurs every 5 minutes, and the two less than 60s intervals add up to sixty seconds.
Is this causing an issue? If so, there are two options that come to mind. First, you can simply disable the automatic refresh by editing 'constants.h' in the ST_Anything Arduino library folder.
Simply uncomment the following line of code
//#define DISABLE_REFRESH		//If uncommented, will disable periodic refresh of the sensors and executors states to the ST Cloud - improves performance, but may reduce data integrity
The other option would be for me to modify the PulseCounter code to ignore the refresh commands (both automatic and manual). This probably makes sense as we are trying to keep track of a specific accumulation of pulses.
I'll look into making the modification to the PulseCounter device.
@tim.ocallag - I have modified both PS_PulseCounter.h and PS_PulseCounter.cpp to exclude this device from responding to 'refresh' requests. This should prevent the timing issue you reported above. Grab both of these updated files and replace the ones you have in your ...\Arduino\libraries\ST_Anything folder, rebuild your sketch, and upload it to your microcontroller.
Please let me know if this resolves the issue you reported above. And thank you for your feedback!
WOW That was fast ..i have to run an errand but will do so after I get back and report back.
Thanks again!!
The problem seems to be fixed ! Thanks
Great. Thanks for the feedback and for discovering the issue!
BTW if anyone wants the hall effect circuit to monitor your water meter I'm happy to post it...it was $10-$15 and I can now monitor water usage
