app:26732020-08-24 12:35:27.123 am error... Uunable to create device Jason iPhone: com.hubitat.app.exception.UnknownDeviceTypeException: Device type 'HubConnect Arrival Sensor' in namespace 'shackrat' not found
Ok, installed the arrival sensor, now getting this error. I made sure to choose the remove the shadow devices from both hubs before I choose the remove option both in ST and in Hubitat. Re-added the ST remote hub and added the presence sensor. Error I was getting is now gone regarding the arrival driver. I verified before re-adding that both the ST Hub and the HubConnect Presence sensor were removed from the hubitat server hub before re-adding.
app:26742020-08-24 01:25:19.017 am error... Uunable to create device Jason iPhone: java.lang.IllegalArgumentException: A device with the same device network ID exists, Please use a different DNI.
ST has done something to SHM today that is causing havoc with some groovy apps. If anyone is mapping SHM —> HSM in HubConnect, you may want to check if it is causing issues. May be time to turn off that option in the ST remote instance.
My ST hub is saying disconnected, but nothing has changed. I'm on HC 2.0 on both devices and it was working fine, until Samsung changed something or their cloud issues.
Now I recall why I left ST
If by chance, you have SHM to HSM mapping enabled in the hubconnect remote client on ST, you may want to disable that and see if it resolves your issue.
Whatever ST did to SHM yesterday is causing a lot of issues with many 3rd party apps.
I feel like I timed my ST departure perfectly , having moved ES and my HSM announcements back over to Hubitat last week. I still haven’t seen any hub slowdown issues related to ES AFAIK. Latency remained unchanged after adding ES.
Ah. No that isn't going to help I think. My sage works fine on my main device hub, I just can't figure out how to share it over Hubconnect. Seems like its not registering a capability that Hubconnect recognizes.
I may try the alternate driver just in case it works differently though.
I didn't investigate very far because I don't own a Sage Doorbell Sensor and thus testing would be short and not so sweet.
I did however download and install the Sage driver to one of my Hubs and then created a virtual device that used that Driver. I then looked at the Attributes exposed by the driver
...and Created a Custom Driver in HubConnect Server. It was probably overly simple but who knows...
Creating a Custom is simple, once you know that the Class Name must be unique and the Driver's name too. For the Sage Doorbell Sensor, it's just a Pushable Button that is exposed by the 'real' driver. So.. a single attribute is all that was needed. Saved that then clicked the Create a Stub driver... again, nothing to it. I clicked Add Refresh and Add Sensor, and put in my name as Author.
I had created the 'real' Sage device on a Remote hub, so I copy/pasted the Custom stub driver to the Server Hub. Then on the Remote, I mirrored the Sage as a Custom and it appeared on the Server, as expected.
Hi Kurt,
I haven't found anything more specific to my issue than this thread, so if I'm in the wrong place, let me know.
My issue is that my locks are not showing up in BitBar on Hubitat like they did with ST.
This screenshot is all I get. Shouldn't I be able to control the locks?
Thanks!
OK it took me a little while to figure out the final step...(reading comprehension for the Win!), but it looks to be connected and presumably working, however its raining, thundering and Zeus is throwing lightning bolts, so i think I'll wait until tomorrow for a function check!
Update: Works perfectly. I can now capture doorbell events on my Ubiquiti doorbell through the Sage sensor. Nice! Thank you @csteele!
I'm having troubles to make hubconnect to work.
I install all the smart apps and drivers on hubitat and smarthings but when I try to connect the Hub Connect Remote Client for Smartthings I get this.
