To add to what @csteele said, the simple answer is because I wanted to. HubConnect is NOT open source and I do not believe GitHub is the appropriate place to post closed source code. I know its not convenient, but hundreds of hours of my personal time have gone into the project, and I no longer have the desire to just throw the code out there for anyone to do whatever they please with it.
I don't get how this will stop people getting the code. Open source or not, the code is "open". It's not compiled so nothing will stop people from reading it. Are you planning on charging for it and adding some sort of phone home?
Anyway, thanks for making this. It has allowed me to make use of my Smartthings hub for some of the apps that cause the hubitat to lock up over time. I just find the new site laid out in a weird way. Finding the code under "support->downloads" seems to be an odd location and took me a while.
The only way "they" will get the code to read is if "you" give it to them. ![]()
I think he just had the Software burning a hole in his pocket.
Been sitting in a 'drawer' for a long time and this is a great opportunity. ![]()
It does not stop anyone from reading nor accessing the code. That is not the intent. But it gives me better control over distribution in that it does prevent one from simply cloning the entire repo into their own account and creating another unauthorized distribution point.
Nope. No plans to charge. There is already a phone home in the version report, but thats kinda unavoidable for the feature to work.
The upshot of this is being able to track how many people sign up and download which gives me feedback to determine how much development effort the project gets.
A little more digging on the mode change issue on the ST side. The issue is that modeStatus returns null so the sendEvent on line 373 is failing. If I comment out line 373 the mode change works smoothly.
For those who are interested, I got a docker container up and running. Turns out you don't have to create a dockerfile to run a node.js script, you can just run node and then execute the script. The command is a bit hacky as it installs every time the container is restarted -- I know there is a cleaner way to do it, but for now this is working.
version: “3.7”
services:
node:
image: node:latest
container_name: HubConnect_Server
working_dir: /hubconnect_server
volumes:
- ${USERDIR}/docker/hubconnect_server:/hubconnect_server
restart: always
networks:
vlan20:
ipv4_address: 192.168.20.34
command: bash -c "npm install -g && node proxy.js"
ports:
- 22010:22010
environment:
- PUID=${PUID}
- PGID=${PGID}
- TZ=${TZ}
networks:
vlan20:
driver: macvlan
driver_opts:
parent: bond0.20
ipam:
config:
- subnet: 192.168.20.0/24
some of the other customizations I've done are in here too. I included the info give the hubconnect server its own IP (on the subnet I keep all my IOT devices on).
you just place the proxy server files in the hubconnect_server folder and it will load then when the container is started.
I asked for docker because install from docker hub will be easier with fewer steps and remove incompatibility on servers already in place.
This implementation works, unfortunately, I don't find this version easier than installing real node.js
I was talking more about:
from registry on dockerhub download image hubconnect with one click
enter IP addresses and ports Hubremotes and hubservers in environmental variables.
done
something like this pihole docker example. deployed in 2 min.
example here:
Does anyone know if the devices remain correctly mapped when switching the connection between 2 Hubitat hubs from Event Socket to oAuth (http)?
I am having some issues with Event Sockets where some remote devices will not show on the server, HSM modes won't replicate and the server keeps thinking it is not connected to the server (even though it is) and I want to test changing to oAuth instead of Event Sockets to see if that might resolve some of the issues without creating new ones...
https://hubconnect.hubitatcommunity.com/HubConnect_Install_Videos/HubConnect_ToProxy/
It's the opposite of your change, but the steps are the same order.
Thanks, great video!
From it, I conclude that the devices will remain - excellent!
This link has been posted multiple times..
http://hubconnect.hubitatcommunity.com/
It got updated the same hour HubConnect v2.0 RC1 was released, with v2.0 Videos and how-to's on NodeJS autostart after boot.
The Import list is still v.1.6.4 until v2.0 goes full release... so keep away from that if you're on RC1.
Also, there's the Link to the Support site as well.
It's almost like Steve and I talk once in a while.
Thanks, yes I thought I had seen it before (believe it or not, I went through the almost 3000 posts before installing v2.0 RC1). I have disconnected and reconnected a few times now, so I feel comfortable with the change.
I switched over from Event Socket to oAuth - The process is really quite easy in V2.0! Bravo!
I was happy to see that all my devices were still there and all the automation still work.
Unfortunately, the issues I was seeing are still occurring...
Yes, I was hoping but really the transport mechanism is rather independent of the Event mechanism.
If I continue the 'highway' metaphor I've used before.. it doesn't matter if the highway is concrete or tarmac, cars and trucks still travel along it in their own lanes.
A bit confused here. I'm finally not using ST at all for anything. I just use HubConnect to communicate with HOOBS so I can use Siri to control the house. Is the only thing that I need to do is just update all the apps and drivers in Hubitat and I will be good to go?
I'm sorry, I can't determine your starting point to the question...
If you have HubConnect v1.6.4 installed and working, at a high level, yes, updating everything from HubConnect.to (not github) will get you to v2.0 RC1
Docs exist there too for an Upgrade or an Install.
Videos covering the Install and the shift to using the optional HubConnect NodeJS Server are at:
So installing the NodeJS Server is not required for me then right?
Optional.. correct.
Thanks, got everything updated. It seems everything is working as it should.
