Thanks @csteele. Oh, how I would like to know what comes after βonβ...
Out of curiousity, if I decided to start with 1.6.4 to test things out but wanted to start fresh again with 2.0, is it as easy as deleting the apps and drivers and starting from scratch once 2.0 is available?
You do NOT have to uninstall to upgrade to v2.0. (This isn't Windows.)
You will just follow the upgrade instructions, which is 95% the Instructions you already followed. There's a SmartThings Hub driver in v2.0 that wasn't in prior versions, for example.
If you installed v1.6 to just experiment and having learned things you choose to start all over, I get it. but I'm trying to make it clear it's not required and probably not what 99% of v1.6 users will do.
I used v2.0 on both sets of interconnected Hubs... I have my 3 Production hubs on one Set and my 2 Development hubs in another Set. All of them were running v2.0 during virtually all of it's development. Eventually I forgot enough about v1.6 that I couldn't answer questions skillfully. I reverted the Development pair to v1.6.4 just to be able to remind myself. On the Day of Release of v2.0, I'll once again upgrade the 1.6 pair to v2.0 by following the Upgrade Instructions. There's an Install Instructions, and since I won't be following that document, I'll ask you to let us know if the instructions need revising.
HubConnect 2.0 PUBLIC Release Candidate 1 Released!
HubConnect 2.0 RC 1 is now available to anyone who wishes to test it.
Please note that this is still not considered production code. It is strongly suggested that only those with a strong technical background and/or experience with HubConnect install it.
Please back up your hubs before proceeding!
What's New in RC1? (from beta 6)
Hubitat: Adds an auto-submit on the Quick Select drop-down to ensure that devices are properly saved.
Hubitat: Fixes incoming mode & hsm events from Remotes to server instance.
That's going to be a requirement going forward. When the final release is made, the drivers will be posted to github, but apps code and the server will need a login to download. I've created a secure, coded downloaded link that's compatible with Hubitats Import function, so a registration doesn't mean you'll be relegated to copy & paste upgrades.
v2.0 has statistics for the NodeJS Server and I've put a lot of attributes into a section of a Dashboard for 'at-a-glance' review:
Clicking Toggle Socket in the HubConnect Hub Device (for ZeeRadioFront) changes the connectio to use the NodeJS Server.
The Attributes are from the Current States list:
The 2nd from the right column are "proxyJitterMS" and the right most column are "proxyLatencyMS"
3rd from the right column are "eventSocketSource" for the HubConnect servers and "connectionType" for Homebridge and SmartThings, since neither support the NodeJS Server.
So I have Hubconnect set up to connect to my HOOBS raspberry pi so I can control everything via Siri. The only thing I had left from my Smartthings set up was my garage door opener. I connected my garage door to HOOBS (MyQ) but I'm wondering why it doesn't show up as a device in Hubitat like all the things from ST did. Amy I missing something?
Did you go into the HubConnect Remote Client on SmartThings and share it to your Server Hub? Does the device show up in the device list on your Hubitat server hub? I'm assuming you're using the HubConnect-Homebridge client on HOOBS? If so, you'll need to re-share the Garage Door controller from your server hub to your Homebridge client.
