[RELEASE]Hub Updater v2 - Update multiple hubs with a button push
v 2.0.11
  • Adds a 'permanent' update delay preference
  • If used it will override the command Delayed Update's parameter
  • Expects a 24-hour clock value, i.e. 02:00
Has this been replaced and now built in to the firmware? I notice now theres a toggle when theres an update to uodate all your devices. Want to remove this if that’s the case.
Thanks.
If you have the toggle when you update this could be removed; still a few that can't get the built-in version to come up.
Thanks!
For anyone still using this, I've added the option to stagger the hub updates every two minutes, i.e. Hub 1 updates immediately, Hub 2 updates 2 min after Hub 1, Hub 3 updates 2 min after Hub 2.....
This should help minimize the amount of concurrent traffic requesting the update and potentially clogging the router's internet connection.
