The change worked perfectly, thanks, except the HPM manifest might be wrong. Once I upgraded manually, all was good, but couldn’t get it to work straight via HPM.
I’ll take a look at it, GitHub and I were having a little disagreement over what was being pushed and what was actually stored the other night.
Installed via HPM, but when I add the Hub Info Device from either of my two hubs, or both of them, I get a blank screen in the app that doesn't show anything.
Just me?
LOL...my wife's dream come true. All HA in the house dead and gone.
Error on line 214?
Oops...forgot to post the log info. Sorry. I removed and re-tried more than once so I had more than one app instance...errors below.
v1.0.8 should be up with the fix
Thank you very much for the quick holiday fix!
Couldn't let the wife win.
She must be doing something nefarious...getting nulls from second hub shared via mesh to first hub, where the aggregation app is running. I did hit the "hia update" button in the info device on the second hub.
- The JVM data you can stop looking at, stopped updating with HE 2.2.8.0;
- max event and state days check your Enable Display of Max Event/State Days Setting in preferences for both;
- cpu5Min and cpuPct check Enable CPU Load Polling in preferences for hub 2;
- the lanIPAddr turn on Include Hub Mesh Data (I need to split it out of that category) - should agree with the localIP unless you are using a WiFi connection
Thanks...have to report PEBCAK failure. I accidentally had two instances of the hub info device on the same hub, and chose the wrong instance in the aggregation app.
Crawling back into my corner...
Just think of the hundreds of others that you just saved from making the same mistake.
Hi,
I am doing a fresh install on a C7 I want to use only for apps after migrating to a C8. Did all the resets to wipe the C7, updated to latest version ( 2.3.5.135). When I have added the Aggregation app it wants me to pick a device of interest, but that list is empty. I installed devices for both V2 and V3 of the Hub Information Drivers, but no luck.
Any suggestions?
Cheers Rene
Use the V3 driver and do a repair or a re-import on the Aggregtion App.
Trying to use HPM to update and getting this:
An error occurred while installing the package: Failed to upgrade driver https://raw.githubusercontent.com/thebearmay/hubitat/main/apps/hubInfoAggDev.groovy.
Be sure the package is not in use with devices.
Can't unselect the hub and Done in the app.
The HPM error you may need to do a Repair on to get the current code although sometimes redoing the update will clear it.
Thx,
Repair fixed it, no longer showing an update and this in info:
- Hub Information Aggregation
- Hub Information Aggregation v1.0.12 (app)
- Hub Information Aggregation Device v1.0.12 (driver)
Which is what I see in the app on Github:
2024-03-29 thebearmay add units to output
static String version() { return '1.0.12' }
Should be good then.
