Thanks again for this driver. I've used it to add my HomeWizard to hubitat a while ago and now I'm going to try to combine it with a dashboard graphing app to show my power usage on a wall-mounted control panel for my smart home stuff. Your efforts are much appreciated, it has worked very well for a while now
Thanks a lot for this driver @fanmanrules.
I did follow your steps to add the device.
But when I open the device I see the following:
Current States
- active_power_l1_w : unknown
- active_power_l2_w : unknown
- active_power_l3_w : unknown
- commStatus : error
- meter_model : unknown
- power : unknown
- smr_version : unknown
- total_gas_m3 : unknown
- total_power_export_t1_kwh : unknown
- total_power_export_t2_kwh : unknown
- total_power_import_t1_kwh : unknown
- total_power_import_t2_kwh : unknown
- wifi_ssid : unknown
- wifi_strength : unknown
I did give the IP adress, but Hubitat cannot get the data.
In the HomeWizard app I enabled "Lokale API".
What do I wrong I get no data?
When enabeling the API in the app, sometimes it takes a while before the setting becomes active.
You can check your connection to the meter by going to the API page in a browser (like chrome).
http://<The IP Adress Of Your Device>/api/v1/data
Thnx for the url @fanmanrules . I discover the issue. When I was sending the logging, I saw that the habitat was in another ip range then HomeWizard. Im using Decomesh system M4.
Now I have set it all to the same ip range and I see the data of HomeWizard in Hubitat!
Very nice! Thanks a lot for this driver!
Your welcome
Tnx for the driver Great work, i have it on a test dasboard,
I now see the used energy power meter — is there also an option to view, for example, the total consumption?
and GAS i don't see the option to add that to the dashboard?
And perhaps an option for a script to display, for example, the previous day's consumption (for example: on Tuesday, the total consumption of Monday, and so on)?
Thanks in advance.
