[RELEASE] Home Assistant Device Bridge (HADB)
It works in HA using the notify command, but not the speak. However, that is not available in HADB, and I do not think it is something I can just swap devices in all my apps and routines. That is why I was giving it a shot with the new capability.
Until they fix the built in Alexa Devices integration (same login issues as echo speaks I think), I can't try that integration. It supposedly supports speak. But I won't know until they update the integration to allow for log in
Is the 2026.11 update breaking anything in HACS? I read that they are deprecating the friendly names in home assistant, and a search in the code shows that HADB is using friendly names to create the labels when creating child devices.
HADB is not related to HACS.
It was not clear to me how the new name scheme would show up through the websocket, so I'm waiting to see exactly what change will be needed.
Anyway the friendly name is only used when HADB creates the device with a label and not used afterward. It does not affect the naming of the HE device which use the entity name instead.
In the mean time, having a label is not crucial and can be set anytime by the user.
Edit: After updating to 2026.11.0, the websocket still send the friendly name as an attribute. No change is needed yet on that regard.
Apologies, I mean HADB. Was too caught up in acronyms looking at all of the changes in this release.
The label thing is what I was talking about. Any new devices won't fail to get pulled over if they do not have a friendly name, correct (thinking more about when they remove that property and the code looks for it but doesn't find it)?
I see the Troubleshooting note that entities aren't actually created until they change the first time. That's frustrating for things that don't change often; would it be feasible to fetch the current state and populate them at initial connection or when the filter set changes?
You can simulate a state for your entity from HA in tools --> states.
