Hi, this is a common question/issue.. the MakerAPI app lets you select what devices are visible to other apps like this one. Open the MakerAPI settings and make sure the new devices are selected. Once saved, they'll automatically show up in the app but you can do a refresh to get them faster
Thanks a lot!
I would love to see a variant of the shade tile that would fit the ZRTS/Somfi controls which are position 0, 100 and 50 representing the "MY" button. The latter is an important control as it allows not only to position to a previously memorized location but also to stop motion at an arbitrary location.
So really, no slider, just a 3-button tile would be great!
Love the idea of the Trello.
May I suggest the following:
Feature request: Allow to change date on Date / Time tile to day/month instead of current month/day (European dates)
Feature request: Remove Empty tiles from number of tiles in folder. Currently, if you have 3 devices in a folder and 5 empty tiles, the number will show 8 on the folder.
Feature request: Allow option to have different "Display Options" for each folder.
Feature request: Allow image tile, when opened, to zoom in and out and/or move image from side to side or top to bottom. Could also be good to allow one to add several images and swipe between them.
Bug Fix: For image tile, crop options only show in the preview (image tile icon). The window always shows the same crop, despite what is chosen.
Bug Fix: Unable to add divider to main page since change to not allow divider to be dropped on folder.
Bug Fix: When adding an image tile to a folder, it is also added to another folder. If I delete it from the second folder, it is also deleted from the creation folder. Haven´t tried with other types of tiles. See video here.
Bug Fix: When adding an icon for a webpage, it will show up briefly, but then be replaced by the page preview. When opening the page, the icon will also show, but only briefly.
I hope this is something that you will consider adding to the board.
I would add one more feature to the date/time tile: Allow an optional link to a website making the tile active that when pressed, the website opens up full screen (for example weather). This would economize/eliminate the need for an extra weather tile.
+1 on this request. I could also use the exact same thing.
- Are you talking about the status text at the bottom-right of the tile? or the main text? The main text can be set to any format you want (search for SimpleDateFormat for examples)
- The status text is so small I'm not sure how useful it is - but I am thinking about changing it to display the month name - ie: "Mon, Feb 22". Also, if you use a wide date tile and have the month and/or day already in the main text I can just hide the status text.
- I'll fix that
- this one could get complex.. are you looking for larger tiles in a folder? Do you have any ideas/examples of how the folder contents could be displayed? I've been thinking of some different options for folders - primarily for folders with just a few devices in them
- interesting ideas! I'll add to the TODO list and try to think of how that could be done
- Yeah, full screen images don't follow the selected crop options. The full screen image display will follow the same dimensions as the device screen - unlike the square device tiles. So, I almost think the full screen view needs a different crop type option..
- ahh.. yeah that's a bug. I was going to say it worked for me but once you view a folder and then back out - adding the section and/or image gets added to the folder you were last in.
- hmm.. I don't see this one; is there a URL you're using to show this? You're using the Web URL tile right and not the App/URL tile? The former is a mini browser and the latter just opens up the application or URL outside of this app.
Yes, talking about the small text, and I really like it, rathern than having the bigger text. Mon, Feb 22 could also work, although in Europe it would be Mon, 22 Feb, but it is better than the numerical. I would encourage to leave the tile as is with the small text (my opinion).
I think what I am thinking here is a way to have for example 6 wide dashboards, which could then be filled with 3 x wide and tall tiles. At least that would work on my device. However, i would not specifically like to have this on all the folders. My use case would be a folder that contains web URLs and Webcams.
Similar to this
Would be great if one could crop the full screen image with the same or similar method as the preview.
Yes, using the Web URL. It seems to be for any web URL. I created a video that shows how it is on my mobile.
Also note, when going in and choosing the Icon, you can do this for just this tile, or all "Image tiles" but I am using a web tile, so the text is wrong I think.
This is my car dashboard (it runs Android 9). The new garage door widget works great! That round area is multipurpose, normally it shows a speedo, clock, map directions, or album art; just swipe up to change. Now it also has the garage door widget!
I think I figured out how to get a specific date format which will change based on locale.. I didn't know about this method before so I'll try it out and update.. that way I can keep the MM/dd format (or dd/MM format) depending on where your device is
There might be another way to do this -- I am planning on allowing some tiles to be even bigger than 2x2. Primarily images/web/video tiles would really benefit from the extra size IMO
I think that would work for devices in landscape mode. It might not work in portrait but I'll do some testing and see if there's a better way
Actually, the bug here is allowing a custom icon to be set for image/video/web tiles since these tiles are meant to be edge-to-edge content (image/video/web page). Are you trying to just show a fixed icon for the main tile and then show the content only when displayed in a large popup?
UPDATE: 2/24 -- not sure what happened with this reply.. I didn't even realize it was my reply until just now...
Exactly this
Running in to issues with the Widget refreshing. In short, it doesn't refresh on its own if the device state was changed else where. I've set the refresh rate to 10 minutes, but it didn't refresh; perhaps because I was in an app and not on the home screen (it was not sleeping)?
What about a long press to refresh the widget (or all Hubitat Dashboard widgets at once)? This shouldn't trigger a state change. This way I'll always be able to verify the device status.
Thanks!
My Hub IP address got changed and the app stopped working. I changed the address back and all is fine, but how would I change the address in the app in the future? I was thinking of logging out and back in, but it said my buttons would be erased.
But it's still better to set a reserved IP address at the router if you can.
Is there no way to change the IP in the app?
In which app? It's in settings of your hub.
But better to set a fixed IP at your router if possible because then there is no chance of a conflict.
sorry for the delayed reply.. you can logout and back in again but just export your settings first and you should be able to restore everything like it is today.
FWIW - I also have my Hub's IP fixed on my router like some others have mentioned
not today.. that's on the TODO list (or if not I'll add it).. although I'm also thinking of having some kind of automatic backup and restore option on logout/login which would make that a better option
The long press won't work since Android only lets you handle clicks on an app widget.
The app should set an alarm for 10 minutes and when that fires it'll try to refresh the state of the device and update the widget. I'm not sure what happens when another app is running - I would think the alarm would still run but it could be delayed I suppose until the home screen is displayed. I'll look into that. What OS are you running on? I know later versions have more logic to delay running alarms. Anyway, I'll see if I can reproduce this and then grab the logs if I can
