I see.. I looked at the JSON and I see 2 devices with 'garage' in the name - a contact sensor and a relay/switch.
For the garage door icons and to have both the open/close state along with controlling the door you'll want to find a garage door driver which has a "GarageDoorControl" attribute. I think this is the one @John.Herron is using from his above post.
I have MyQ openers so I'm using this driver. I need to use IFTTT because the MyQ API doesn't allow querying the state of the door for Hubitat directly; but does for IFTTT
