[RELEASE] HD+ - Android Dashboard
@jpage4500
So I had a look back through previous posts in another thread (posts 44 to 55 in this thread - Honeywell Evohome - #44 by johnwill1) regarding the correct display of this thermostat (Heat only with controls available regardless of mode).
Apparently it uses the Thermostat Heating Setpoint capability. When it was added in Sharp Tools it had to be added as a Temperature Sensor which then exposed that additional capability. It's different with Sharp Tools in that once you add a device tile under its main capability, it's then possible to edit the tile layout to show any of the devices available capabilities.
