OK, got it working. The child devices actually don't need virtual container driver.
I found the imports pretty flakey and I had to rename the child devices to correct the formatting.
Some things you need to know:
The child device ONLY activates the program. It does NOT turn the H801 on/off
The Parent device is the ONLY way to turn off your programs
This means that 'stop' in the child device just stops the Red/Blue flashing (Police Lights) but leaves it on Red or Blue!
Edited - In the other thread I see it is how it is expected to work.
You are. "When program is finished" is what happens when the program finishes. If it runs forever it never finishes. If you "stop" the program it does exactly that. It stops the program in the state that it is in, whatever the color might be.
So there is a simple solution to your problem. You don't "stop" the program you turn "off" the controller.
New to Hubitat here.
But will this work with the outlets as well, or just bulbs. I have a few of them but that I need to replace with Zigbee, but wondering if this would work in the meantime.
Evening, morning, good day - wherever you might be...
I've just flashed a H801 and have associated the device to my wifi network. I can also access the configuration menu via the IP address my router has assigned to the device. I've also been able to discover the device in the Smartlife Connect app in HE. The issue is that the device is not responding to any controls - either via the IP menu or HE in the device screen.
After reading through a few comments on both Hubitat and Smartthings, it sounds as if the RED and GREEN LEDs should be on when all working - whereas mine are not.
Does anyone have any suggestions on how to correct this? I have flashed the firmware and reset a few times to see if I can kick it out of this "mode". Any advice would be appreciated. This would be the last item I am migration from Smartthings so keen to close that book
Thanks!
Update: Interestingly, when I control the device from the IP address, the HE device attributes are updated however they seem to jump around rather than stay on the setting sent from the IP address controller.
Hi,
Sorry for this late and admittedly stupid question but does any one have a guide on how to flash the FW onto the controller? Is this OTA or does it involve soldering? Would really appreciate some help - thank you!
Thank you, Eric! and thank you so much for all the code you've shared. Don't think I - a non engineer - would even have this hobby if it weren't for you!
Hi Eric,
Sorry for bothering you again but wanted to run this past you. Turns out my chip isn't an H801 - here's the blueprint. Would this version work on it? Thank you!
