The Hubitat C3, C4, and C5 hubs all share very similar specs of a Quad-Core ARM CPU, with 1GB of RAM and 8GB of Flash storage, if I recall correctly. I believe the TTS cache is limited in size via the platform software to make sure it does not consume all of the flash storage. I do not know what the size limit is for the TTS cache.
Update: Found an old post from Mike Maxwell that states the TTS cache is limited to 5MB of storage.
Very helpful discussion, I am new to Hubitat and have the Asistant relay working and commands from Hubitat working in Virtual Devices, not sure if I am missing the obvious but I cant seem to save the text commands in the virtual device. I select save preferences and save the device go back in and no device notification or speak command is saved. Is this only for testing ? do you have to use rule manager to send saved action and commands to GAR ? Any help would be appreciated
Hubitat Version 2.2.3.119
guys, I am using this google assistant relay driver V3 and I prefer it above other solutions only because if I have music and there is a voice notification the music will resume after the notif but there are some cons such as there is an annoying voice saying "broadcast from user" followed by the notification itself and the notifications are just sent to ALL the google devices I have with out the option to select an specific device to broadcast to and it could be as well because when using the broadcasting function triggered by my voice to spread a message it works the same only able to send to all devices at the same time together. The good news are that today I found that I am able to broadcast messages to an specific device, so when I say with my voice "broadcast x message to kitchen speaker" it will actually do it to that specific speaker only. I am wondering if with the google assistant relay driver this is now as well possible, if anyone know I will appreciate
I'm running into a couple issues with GAR (v3, driver v2), and hoped someone may have already figured these out.
I can get broadcasts to work (same gripe at Google about lead in announcement), I can get [P] commands to work. However, if I try [CC] or [CCC] commands, they come out as broadcasts of the commands, but no responses (I'll be honest I'm not sure which one is supposed to be the silent one because they always just broadcast). I did try testing using Greg Hesp's sandbox on the server, and even with the json that gets sent, I still get the same results. I did find that if I use the very generic "tell me a joke", then I do actually get the joke stated (or on the popup message if using the converse=false). However if I switch to something like "what's the weather" then it just broadcasts the command (this is a question I have no trouble getting a response accurately when I say it to an actual Google Home). On the popup on the sandbox it says there's no text result. I can't tell if this is a nodejs issue, a driver issue, or maybe it's a Windows issue?
My only option right now for hosting nodejs is on a Windows 10 computer that stays on all the time. I think I got a service setup to run it even when not logged in, but it seems to stop working if someone else logs in that doesn't have administrator rights. Does anyone know the OS well enough about why that may be?
First, just to be clear, I have not used GAR in quite some time. So, I am replying based on my experience quite some time ago... You may want ask Greg Hesp directly by posting an ISSUE in his GitHub repository for the latest, up to date answers.
[CC] = custom command, there should be no broadcast if this is properly used as a prefix. For example, “[CC]turn on hallway lamp” - this would turn on a light named “hallway lamp” that is connected to Google Home.
[CCC] = custom command with conversation. “[CCC]tell me a joke” would hopefully result in a response from a google home device. However, this is very, very limited in functionality. Most things result in no response whatsoever. This is normal and has nothing to do with your setup.
@ogiewon
Thank you for the clarification. I don't yet have devices installed that could be voice controlled by Google as I'm just starting out, so that will be something I need to try. Also, due to my novice situation, I don't know much about GitHub, but I'll gladly ask Greg. From your answer it sounds as if the limitation is Google's. I mean really...make the joke work, but not the weather?
I am having a problem and I just can't figure it out. It seems like I may have a Google issue but not sure. I am walking through the instructions and going step-by-step but I just cannot get past the OAuth consent screen. I created the project, enabled the API, go to create the OAuth but it insists I edit the consent screen first.
Throw my email in the user support email and the developer contact information email addresses, App name is already filled in for me, Authorized domains is already filled in for me, leaving everything else. Click SAVE AND CONTINUE and it shows “An error saving your app has occurred” and nothing more. Anybody else seen or dealt with this? I just cannot get past this at all.
I'm migrating from ST to Hubitat and I'm trying to understand what do I need to do to get AR working. I have been using it on ST side and broadcast by using webcore pistons. Now I copied my pistons from ST WC to hubitat WC and none of my broadcasts goes through.
I thought (I could be very wrong) that since nothing changes (ar server ip is same) I just continue to broadcast to same destination address with same destination port..but now I'm clearly missing something.
This could be the part where I'm really stupid but ...
Do I need to install AR drivers (?) to hubitat if I'm just broadcasting to ip address and port where AR has been and still is running?
