Its the latter. I dont use it in occupancy mode. I just issues commands from the hub based on a rule- If motion changes to off, wait 3 minutes then turn off light. The rule is a bit more complex than that because it also leaves the light on for up to 30 minutes if someone manually hits the on button.
If I remember correctly I believe hub is receiving the event of the motion becoming inactive and the hub then shows the light as off but the light is actually still on. Not sure of the logs.
