@storageanarchy Thank you for the work you put into this. Works wonderfully! You should have "Developer" after your name like the rest of them.
How do I get rid of the "TWC weather data is not available on Hubitat - please configure DarkSky or MeteoBridge for forecast data" that keep showing up in my logs? Everything I do, it's still there... I like clean logs...
Thanks for the compliment - I imagine I will eventually be awarded the "Programmer" badge.
That message should go away if you select to use either the MeteoBridge forecast data (requires a Davis weather station), or configure Dark Sky as your forecast source.
Otherwise, you can comment out the message in the source file...
