Meteobridge Weather Station v1.1.28 released on June 26, 2019
Overview
Meteobridge (www.meteobridge.com) is an inexpensive Linux-based server that is used by many to collect data from your local weather station and distribute it to one or more public weather sources (including Weather Underground, for example). It supports data collection from a large number of popular weather stations, and it offers a local API that allows clients/applications to retrieve the latest weather station data on demand.
This weather station DTH uses local hubAction() calls to provide pretty much all information exposed by The Meteobridge Template HTML API, which it retrieves as a JSON formatted map. While the DTH is optimized for Davis Vantage Pro2 Plus stations, it will report whatever subset Meteobridge provides for any connected weather station.
This device also (optionally) calculates and displays Purple Air Air Quality Index from a specified PurpleAir sensor. If you don't have one of your own, you will need to do a little research on the PurpleAir.com website to find a sensor nearby and then find its device ID from their JSON repository (search the repository for the name displayed for the sensor on the sensor map, then enter the numerical ID of that sensor into Preferences).
As most weather stations do no provide forecast details (hi/lo temps, humidity, probability of precipitation, etc.), this DTH allows selection from 1 of 3 sources for forecast data:
- Dark Sky: probably the best forecast source for PWS owners, as they provide hyper-local forecast data that probably includes data from your weather station (if you send to CWOP). Note that to use Dark Sky, you will need an API key, available on their web site - this DTH will use about 96 Dark Sky API calls per day;
- The Weather Company: now owned by IBM, and now the official SmartThings weather service, with location-based forecast data that probably does not include any input from your weather station;
- MeteoBridge/Davis: Davis Vantage Pro weather stations do provide a calculated forecast string; the code will drop back to use TWC for the rest of the forecast data if you choose this option
- Weather Underground support has been removed, because SmartThings has replaced the getWeatherFeature() linkage to WU in favor of the above-mentioned TWC support.
Significantly, EVERYTHING that this DTH displays in Tiles is also available programmatically to other SmartApps and WebCoRE pistons. You can thus build apps and integrations based off of changes in any attribute, from temperature and humidity to air quality, lunar phase, wind speed and the like. If interested, have a look at the attributes listed at the top of the source file for the names of the available data points.
Hubitat Compatibility
Thanks to the assistance of @staze and the Hubitat Community plus some code borrowed from Echo Speaks (thanks @tonesto7) this DTH can be used on Hubitat without modification! It will auto-detect the hub platform, and adjust its calls, classes and parameters appropriately for each platform. There are lots of incompatibilities between the two platforms, but clever utilization of Groovy allows a single code base to support both. Of course, on Hubitat there is no UI, but all of the attributes are programmatically available to apps and Rules Engine on that platform.
New in version 1.1.28
MeteoWeather now fully supports the native Hubitat Dashboard Weather Tile. Assigning this device to the Weather Tile will result in this:
MeteoWeather also generates an HTML weather snapshot, designed for use with the HE Dashboard. To access it, create a 2x2 tile in the Dashboard, first select your MeteoWeather device. Then select the "Attribute" template, and assign it to the "myTile" attribute. The resulting display looks like this:
Note that the above display just barely fits within the 1024 character size limitation of the "myTile" attribute.
Important Note for All Users
Since this DTH uses hubAction() for the MeteoBridge data, it will work only when your SmartThings/Hubitat hub and your MeteoBridge/WeatherBridge server are on the same (local) IP network. This approach keeps your password safe(r), but doesn't handle remote IP addresses. On the plus side, it is pretty lightweight to get updates from your meteobridge every minute, unlike using the WeatherUnderground data source.
The GiThub repository for MeteoWeather is here:
Installation
You can either manually copy/save the DTH code, or you can use the following for SmartThings' Github integration:
Owner: SANdood
Branch: master
After loading and publishing the DTH, you will need to manually create the device from the Devices page in your IDE. Once created, use your Mobile App to configure the preferences for your new Meteobridge-based Weather Station!
Donations
This work is fully Open Source, and available for use at no charge.
While not required, I do humbly accept donations. If you would like to make an optional donation, I will be most grateful. You can make donations to me on PayPal at https://paypal.me/BarryABurke
Attributions
Powered by DarkSky
Weather forecasts and somne current conditions data (e.g., cloud cover) provided by https://darksky.net/dev
VClouds Weather Icons
Icons provided by VClouds Weather Icons by VClouds VClouds Weather Icons© Created and copyrighted© by VClouds - http://vclouds.deviantart.com/
The icons are free to use for Non-Commercial use, but If you use want to use it with your art please credit me and put a link leading back to the icons DA page - http://vclouds.deviantart.com/gallery/#/d2ynulp
*** Not to be used for commercial use without permission! if you want to buy the icons for commercial use please send me a note - http://vclouds.deviantart.com/ ***
Change Log:
| * | 1.1.10 | Initial Release (March 20, 2019) |
| 2019-03-24 | 1.1.15 | New SmartThings/Hubitat Portability Library, Bug fixes |
| 2019-03-24 | 1.1.16 | Fixed TWC error (state.isHE) |
| 2019-03-26 | 1.1.17 | Major bug fixes, new icons, new myTile attribute for Hubitat Dashboard |
| 2019-03-27 | 1.1.20 | Improved handling of non-existent sensors and missing data |
| 2019-04-02 | 1.1.23 | Major overhaul of template structure for better error handling & efficiency |
| 2019-04-22 | 1.1.25 | Option to use data averaged over the update cycle instead of actual reading |
Screen Shot:
