Definitely not working for me and Iām in the US.
Neither normal login/refresh nor manual token work.
Just tried mine again and not working. I'm in US.
I am down in the US too.....waiting patiently for a fix.
app:20592019-06-20 08:07:04.687 am errorjava.lang.IllegalArgumentException: No json exists for response on line 1116 (cookieRefreshResp)
app:20592019-06-20 08:07:04.685 am tracecookieRefreshResp...
app:20592019-06-20 08:06:46.048 am debugDevice Data Received and Updated for (2) Alexa Devices | Took: (1987ms) | Last Refreshed: (10.0 minutes)
app:20592019-06-20 08:06:34.780 am traceprocessData Received | Version: 2.2.1 | onHeroku: true | serverUrl: null
app:20592019-06-20 08:06:34.578 am tracegetCookieData() Request Received...
app:20592019-06-20 08:06:34.439 am debugwakeUpServer Completed... | Process Time: (308ms)
app:20592019-06-20 08:06:34.439 am tracewakeUpServerResp...
app:20592019-06-20 08:02:04.695 am errorjava.lang.IllegalArgumentException: No json exists for response on line 1116 (cookieRefreshResp)
app:20592019-06-20 08:02:04.688 am tracecookieRefreshResp...
app:20592019-06-20 08:01:34.784 am traceprocessData Received | Version: 2.2.1 | onHeroku: true | serverUrl: null
app:20592019-06-20 08:01:34.572 am tracegetCookieData() Request Received...
app:20592019-06-20 08:01:34.369 am debugwakeUpServer Completed... | Process Time: (278ms)
app:20592019-06-20 08:01:34.369 am tracewakeUpServerResp...
app:20592019-06-20 07:57:04.666 am errorjava.lang.IllegalArgumentException: No json exists for response on line 1116 (cookieRefreshResp)
app:20592019-06-20 07:57:04.663 am tracecookieRefreshResp...
app:20592019-06-20 07:56:46.044 am debugDevice Data Received and Updated for (2) Alexa Devices | Took: (1992ms) | Last Refreshed: (10.0 minutes)
app:20592019-06-20 07:56:34.818 am traceprocessData Received | Version: 2.2.1 | onHeroku: true | serverUrl: null
app:20592019-06-20 07:56:34.589 am tracegetCookieData() Request Received...
app:20592019-06-20 07:56:34.400 am debugwakeUpServer Completed... | Process Time: (264ms)
app:20592019-06-20 07:56:34.400 am tracewakeUpServerResp...
app:20592019-06-20 07:52:04.743 am errorjava.lang.IllegalArgumentException: No json exists for response on line 1116 (cookieRefreshResp)
app:20592019-06-20 07:52:04.736 am tracecookieRefreshResp...
app:20592019-06-20 07:51:34.908 am traceprocessData Received | Version: 2.2.1 | onHeroku: true | serverUrl: null
In US. Manual cookie entry via Heroku worked for me. Needed to input both cookie and csrf values.
What method did you use to get the cookie for manual entry?
Did you have to remove double quotes or add anything to the cookie?
Update: Disregard. The manual cookie and CSRF worked.
Update 2: So the manual entry of the cookie and CSRF was accepted and the app shows a cookie date of today, but my Echo devices are not actually announcing anything.
I followed the steps of @rvrolyk and entered the cookie manually. What is the CSRF and where do we get it? Also, how will I know if it is working?
After you initially copy the cookie from the browser, paste it into a text editor. The CSRF should be one of the items listed. I missed it at first.
As I posted above, even though everything seemed OK in Heroku with the manual entry and Echo Speaks shows a cookie in the app on HE, my Echo Dots are not announcing.
@pcgirl, sorry I forgot to mention the CSRF. As @jkudave mentioned, it's buried in the cookie string itself (csrf=...).
I don't have any Dots but my Tap and 1st gen Echo did work last night and this morning.
@rvrolyk I can see the CSRF in the data. Do I include that also in the cookie or do I just take the data up to the CSRF for the cookie? Which part of the CSRF do I enter? Just the number after CSRF=?
I used the entire cookie string and it seemed to work.
For the CSRF you just want the number after the =
I think it worked because my Echos are showing in the log now. Not sure if they are working though as I am not at home.
Mine show too, but are not working.
I got all that but non of my echos are speaking.
The only app that's working with the cookie is the Alexa TTS one by @ogiewon
OK. Got things working. Redid the steps to get the cookie using FireFox instead of chrome. Added a semicolon to the end and pasted it into the Heroku app, along with the CSRF. Everything seems to be working for the moment.
Finally got my echos to speak....However auto refresh for cookie does not work. So until that is fixed I am using @ogiewon Alexa TTS app to notify me when the cookie doesn't work anymore.
I will have a server update out this afternoon with fixes...
I'm almost caught up at work then I can work on the fixes...
Status Update: I have the fix inplace and it's tested. I want to make a few more tweaks before I push out the changes.
