[RELEASE] Echo Speaks V4
I think I figured out what was happening, as I did get it working. I had forgotten how to use pm2 to restart echo-speaks so I figured, what the heck just restart vmbox! That is not the same apparently. Once I restarted with pm2 restart echo-speaks --update-env, it worked
Anyone get this working past the login issues that do not persist?
Um, yes. Has worked since day 1 on local login server (non Heroku) on a Raspberry Pi. No issues.
@Pantheon said:
I had a terrible time with the Amazon login stuff with Echo Speaks. If you are getting the pin code request when you log into Amazon like this then you will have to turn this off. I had to contact Amazon and request that it be turned off. Then I turned on 2FA to log into my Amazon account. I did not have that set up prior. Once I did that, I was able to log into Amazon (through the Echo Speaks install procedure) and get the cookie renewed. Not sure if this is your difficulty. But this is what was messing up my Amazon cookie refresh.
I'm in the same situation, running the cookie server on my Synology NAS (not under Docker, but a pm process under node.js). It had been running like a champ for months but I see from my server logs that it started to go south throwing errors around Nov '23.
This afternoon I started digging into it, starting with refreshing the cookie. When I saw this OTP screen pop up during Amazon authentication I thought that 2FA had been turned on even though I knew I hadn't done it myself. I receive the OTP successfully from Amazon but when I enter it I get a browser error message that the cookie server's authentication process can't post the OTP:
I wonder how to turn off OTP on login if it's not 2FA? Spent 1.5 hours on chat with a series of Amazon CSRs but nobody seemed to be able to turn it off.
Enable 2fa on your Amazon account and it will work. Someone else went through this recently and posted about it.
I had to stop my echo speaks server, then go to the echo speaks app and clear the server settings a few times. Started the server and then tried logged in again. All worked again.
I spent about 45 minutes on chat with Amazon and ultimately found someone who said they could turn OTP off. They said it would take about 24 hours to ultimately turn off. I did activate 2fa. The OTP did turn off and with 2FA on ES works well. I struggled a lot with this process before that.
OK, I've turned on 2FA and I see that the process of that also has an option to disable OTP on the specific browser (I assume by setting a browser cookie.) I will try authenticating the ES cookie server on my local NAS by logging into Amazon again.
The other intermittent issue I've run into which has appeared again this morning is that bringing up the ES authentication page served by the index.js script running on my local NAS at 192.168.0.4:8091/proxy sometimes results in this result from Amazon:
As I say, it is intermittent but is persistent for some time once the 404 error is thrown. It is possible that there is a timeout for this error and that by waiting - an hour or two? - something resets and the login will go through. But at the moment this is where I'm stuck - I'll try rebooting the NAS and see if restarting the cookie server makes it all work again.
That might be caused by an incorrect IP or other setting. Here is a guide for local echo speaks server: [GUIDE] Echo Speaks Server on Docker (or without)
I've never seen anyone do it via proxy... not that it shouldn't work, just wonder if there is a delay inherent causing an issue.
Thats an URL used by the cookie server. It uses a built in proxy system to trick the Amazon site into letting you log in. Not sure how it works exactly, but it is using an internal proxy / relay system of some sort.
I now seem to have gotten past the 404 error; http://192.168.04:8091/config serves the Echo Speaks server config page and the "Goto Login Page" link to http://192.168.04:8091/proxy now resolves correctly to the Amazon login page.
Also - now that I have enabled 2FA but disabled OTP, my Amazon authentication is accepted without having to jump through the extra hoop of OTP entry.
I had one final issue that required digging into the cookie server's index.js javascript running on my NAS. Instead of using the local IP address of my server at 192.168.0.4 the ES app was picking up this strange IP address "10.8.4.48:8091" as if it were the cookie server, and naturally failing to connect to it:
It turns out 10.8.4.48 was a (foreign, in Singapore) interface address assigned by a VPN that I also have running by default on my NAS. :roll_eyes: Once I tricked the script into skipping over that network interface everything started working again.
The guide that I linked to above has instructions for how to set the IP correctly, and was the reason I provided that link. I had assume that was one of the issues you might be having.
suddenly a whole bunch of new echo speaks devices showed up in my hub not sure why ..
there are non functional as for instance i dont believe shields are echo devices. maybe something to do with the alexa app.. i beiieve they are shields and rokus?
Maybe they added some sort of Alexa abilities to those devices with an update and now the app thinks they are speaker devices. Or did you recently log into your amazon account on those devices? You can just mark them as excluded in the app and run the cleanup to get rid of them.
Havent used a few of those at all recently but i think they are inline in another house . Anyway, they were not in the list to exclude. But the cleanup switch seemed to remove them anyway.
So im running 4.2.2 Should i update I had trouble getting the cookie to work and once its working i worried the update will break it. I could not keep the docker image working. Can this version logon by itself or does it still require the docker image.
I still dont understand why it cant run on hubitat and get the cookie from the app.
You have the source code on your Hubitat. I've looked at the code - I can see at least one reason why - there is a lot more going on than you might think. We just need someone motivated enough to do it.
I'm trying to send command to my echo so I can operate Amazon Thermostats from Hubitat. However, when I put something like "set office thermostat to cool", and check in alexa activity logs it shows like 3 lines "", then my command and then another "" and is ignored, what am I missing? I can crate fake buttons and call then and then do routines but it is kind of annoying...
To my knowledge, you cannot do this. Echos require voice commands. I do know someone who placed a speaker next to an isolated Echo. He would send voice commands to the speaker which would "speak" to the Echo to do what he needed.
[EDIT] I don't know if you can do this with a speaker plugged INTO an Echo. That would be an interesting experiment.
