Didn't look since I knew .135 was moved to a production release, but @dennypage is correct in that there is a known issue last causes the Last Activity to not be updated consistent with the past experience, and as noted it is slated for a fix in an upcoming release.
And no idea when next prod will be released... so annoying to get constant updates for no activity in x days for nearly every device.
Is this no longer available in Package Manager? Package manager keeps throwing an error:
Bad manifest for Hub Watchdog. java.lang.NullPointerException: Cannot get property 'betaLocation' on null object Please notify the package developer.
I wonder, is it possible to show the health attributie (online/offline) in a color?
I would like to trigger an event when a device come back online. Is this app would do the job? Webcore seem to not use status as trigger for wifi devices. I would like that to be in real time, not ceduled if possible!
Thanks!
I have installed Buddle Manager, followed by Normal Stuff Library, but when I go to install Device Watchdog it says " Device Watchdog requires Normal Stuff Library be installed BEFORE Device Watchdog can be installed." I have confirmed Normal Stuff Library is installed, I have rebooted the hub, but keep getting this error. Any ideas on how to resolve?
It's right in the first post...
I think I had to install the bundle
https://github.com/Bundles/DeviceWatchdog.zip
Thanks @bptworld and @TArman , is there a better solution for getting device notifications that have dropped off z-wave or ziggby network?
Device Activity Check is what many of us use.
Agreed
Thank you!
Device Watchdog has been re-added to Hubitat Package Manager.
If you already use DW then be sure to use the 'Match' function before downloading DW from HPM.
2.4.9 - 4/13/24 - Many changes, back in HPM, added ability to color code reports with Attributes
Hey @bptworld, nice to see Device Watchdog is supported again, thx for that, the app is really helpful for me. Concerning the color indication of the health status in the attribute report, what I ment was to give the offline/online also a color.
This is strange to, motion has no color, I need to remove the 2 attributes to see the color:
same for switch
I hope this feedback does not discourage you from supporting it again
I guess the HealthStatus should add here...
Try 2.5.0, it should fix the issue.
I think I have found the issue, it was a conflict between app/drivers I saw the parent twice, I removed the Bundel manger and all drivers in all sections, did a repair in HPM, now it looks OK.
When Installed the new version using HPM I followed your instructions to do this, Will test later this evening and give some feedback.
