This is not an app problem or bug ive never said it was (but have now emphasised it in bold), it is a quirk of a specific Hue lamp, brought to light by using this app, even rule machine sending a configure command would turn the light on blue.
updated my post accordingly noticed that i wasn't on the latest version and you had added a config option toggle
Device watchdog is working very well for me. One minor problem I am facing though, is with my "sengled element classic" bulbs, which are using "advanced zigbee bulb" driver. These bulbs are in a part of the house, where they are used less often. The problem is that if the bulb are not switched on, the last activity field does not get updated. This causes device watchdog to mark it as an issue device. Do I need to be turning each bulb in the house on and off every few days for device watchdog to work? Does not seem correct.
Nope, most (if not all) devices 'check in' every once in a while. Even if it hasn't been used. Every device is different, some are hourly, some are 4 hours .. but most are within 24 hours.
If you find a device that doesn't, then the best thing to do is make a new thread about the device/driver combo and see what experience others are having with that device. It could be an issue with that particular device and/or the driver.
Same issue with the "Generic Zigbee Outlet" driver if the outlet does not do power monitoring. Mains powered zWave and Zigbee devices typically do not check in. I brought this up before but the devs did not seem interested in fixing the driver to send an event upon the device being refreshed. Sending an event would update the Last Activity date/time stamp.
I noticed there is an option in device watchdog to optionally use 'configure 'while checking status. I have enabled that now to see if it helps, though this will still be a hack.
I have been unsuccessful in getting DW to upload and run in Hubitat. I have Bundle Manager HPM loaded, which seemed to be a prerequisite. However, when I try to get Hubitat to open the downloaded local DW zip file to load the app, I get this error:
"library not found on line 45: #include BPTWorld.bpt-normalStuff"
If I try to use the URL for the zip file in Hubitat, I get this error:
"Cannot process bundle"
Did you run Bundle Manager HPM? It's only a placeholder and will setup the full Bundle Manager. Once that is setup, use Bundle Manger to download anything you want.
Thanks! Forgive my ignorance, but I don't know how to "run" it. If I click the BM HPM link in the Apps Code tab, it just takes me to the code itself. DW Tile is listed in the Driver's Code tab, but not BM HPM. Nor is it listed in the Apps, as you point out. So, where do I "run" BM HPM from?
Update: Never mind! I finally realized the "Add User App" button on the Apps page (rather than Apps Code page) was all I needed. Instructions for the Bundle Manager, as well as the instructions for your other bundles, are clear and helpful. And DW is now up and running. Thank you for your help, and your app.
Hi Bryan - before submitting logs etc wanted to make sure I understood expected results. I have Dev watchdog setup monitoring activity and battery on various device. When I run a report on activity, I see several devices where last activity is greater than the 48 hrs I have set as the interval to be considered inactive. I also have a virtual switch configured to turn on when there are inactive devices to report. However, the switch appears to never turn on.
Same thing with Battery - there's a device with low battery in the report, but the virtual device for battery doesn't get turned on.
Am I understanding expected behavior correctly? Is there some additional configuration I missed that would prevent those switches from turning on?
A bit more information - this may or may not have anything to do with not turning on the device when there's an issue:
I've been getting notifications from hubitat that simply say "Nothing to report". I haven't been able to determine what app is sending them yet. As you can see below, I have Device Watchdog configured to only send a push if there is something to report, so I assume it should not be coming from there.
I'm just wondering if there is something in the underlying logic about when to send a push and when to turn on a switch where I've configured things in the wrong direction. Happy to post logs but I'm not sure what to post.
Hi @bptworld , how do I configure "Status report" so that it only reports devices for specific status. for example "not present", I don't want to have report, I would like to have report only when there is something to pay attention to, for example to replace battery or re-connect sensor, makes sense?
Thanks, I am configuring "Activity" report, however I don't see why you can't add same option for "Status" report as for Activity, namely "App will only display NON-PRESENT Devices"
Reason I am saying that I found Status report very accurately detects ZigBee device issue as most of the device report presence nowadays. You can have additional Filter option for filtering NON-PRESENT status only, again it works very well and I don't see why limit Status to what it is now and not include option to report NON-PRESENT devices.
You will need to test... Currently, the battery-powered devices that use TS004F driver will report 'healthStatus offline' after 12 hours of no any activity received form the device - key press or battery report or anything else
