I think that only you can delete an app so not sure how this happened. If you run into any further problems you could try my adaptation. I did uncover a few more things through trial and error but I did not test everything.
Thanks! i upgraded to your version - like the ability to track/alert oil levels . Also like the ability to set intensity just not sure how to set run and pause times. Would love to do that within Hubitat as I have different needs during cooling and heating seasons.
I’m not sure all of that works. I have slowly been discovering the endpoints and adding them to the driver. But the unit reports stuff and never updates it. Test it out and see what happens.
I'm not seeing any response to the duration commands that I put into device page. Let me know if you ever figure it out. Thanks!
I just re-ran the proxy capture and got more info. I have figured out the JSON packages for schedules and durations (I think) so working on testing those.
I have never seen a low oil, even though that is in the JSON packages. I will have to empty one of the bottles and see if it works.
Also in Concentration - I assume A is lowest and C is highest? I can't find any documentation on this.
Also,
I don't think my diffuser even has a setting for concentration but it could be it is adjustable through the API. I was mainly looking for Work and Pause times so I can adjust those based on different running times of the HVAC unit
