Have you already installed the Zigbee Map app ?
Do the following :
pair the RTCGQ11LM very close to the hub. Make sure it works. You may need to pair it 2-3-4-5 .. times, Ensure it changes motion active/inactive reliably.
Check the Zigbee Map - you will probably see the motion sensor paired directly to your hub. This is the problem - Aqara older generations battery-powered devices must be paired via an compatible Zigbee repeater (router)
Without deleting the sensor, pair it again, but this time very close to a mains-powered Zigbee repeater (router). By 'close' I mean nearly touching the repeater, so that its signal is so strong, that the Aqara sensor does not hear anything else, except that repeater.
Refresh the Zigbee Map. You must see a picture like this - the Aqara sensor is now communicating via your repeater of choice :
If the map still shows a direct connection to the hub - pair it again very close to the hub (step 3).
Verify that the sensor still works.
