[RELEASE] Advanced Lighting Circadian Rhythm
Hello everyone! I'm excited to share a custom app I've been developing: Advanced Lighting Circadian Rhythm.
This is a commercial-grade Circadian Rhythm engine designed to calculate the natural solar color temperature based on your local sunrise and sunset. Instead of directly fighting for control over your bulbs, it outputs the exact calculated Kelvin value to a Hubitat Hub Variable, giving you the flexibility to use that variable in your own rules, WebCoRE pistons, or lighting apps.
:glowing_star: Key Features
  • Live Circadian Dashboard: Provides a real-time view of the sun's position, your outdoor lux, and the exact color temperature (Kelvin) the engine is transmitting to your Hub Variable.
  • Daytime Storm Compensation: Connect an outdoor Lux (Illuminance) sensor. If it gets unusually dark during the middle of the day (like a heavy rainstorm), the app will temporarily drop the color temperature to a cozy, warm setting until the sun comes back out.
  • Manual Color Overrides: Instantly locks the color temperature to a specific value, bypassing the sun logic entirely. This is useful for tasks requiring bright white light at night, or forcing cozy lighting during a dark storm.
  • Master Kill Switch: A master toggle that stops the app from updating the Hub Variable completely, allowing you to manually control your lights without any interference.
  • Circadian Rhythm Boundaries: Defines the absolute floor and ceiling for your color temperature. You can easily set these to match the physical limits of your specific smart bulbs.
  • Customizable Update Frequency: Control how often the app recalculates the sun's position and updates the Hub Variable. Options range from every 1 minute to every 30 minutes.
:unlocked: 100% Free and Open Source
This is entirely free-use code. It is fully open source, free to use, and free to edit. You are highly encouraged to modify the code, adapt it for your own unique setup, and do whatever you want with it!
raw.githubusercontent.com/ShaneAllen334/Hubitat_Apps/refs/heads/main/Advanced_Lighting_Circadian_Rhythm/Advanced_Lighting_Circadian_Rhythm.groovy
1. Integrated Dimming Intensity Engine
The engine has evolved from a color-shifter to a full intensity-management system. It now calculates a parallel Dimmer Level (%) curve alongside the Color Temperature logic. This allows your home to not only change "mood" but also reduce total light output as the day ends to better align with natural circadian triggers.
2. Selectable Curve Logic: Standard vs. Inverted
You can now define how the brightness behaves relative to the sun’s position:
  • Standard Curve: Mimics the sun (Brightest at Solar Noon, Dimmest at Night). This is the gold standard for indoor living areas to help with evening wind-down.
  • Inverted Curve: Flips the logic (Dimmest at Solar Noon, Brightest at Night). This is a game-changer for outdoor security lighting, landscape lighting, or rooms with significant window glare that need "fill light" only after the sun goes down.
3. Expanded "Output Destination" Protocol
To ensure the engine fits into any automation architecture, we’ve added a flexible output selector. You can now route the calculated Dimmer Level to:
  • Hub Variables: For those using Rule Machine or custom logic.
  • Virtual Dimmer Devices: Allows any standard "Mirror" or "Follower" app to treat the circadian engine as a physical reference point.
  • Dual-Broadcast: Update both a Variable and a Virtual Device simultaneously.
4. Adaptive Dimmer Boundaries
To protect your hardware and ensure the lighting remains comfortable, we’ve added explicit floor and ceiling controls for the dimming curve:
  • Min/Max Level Settings: Define the absolute lowest (e.g., 10%) and highest (e.g., 100%) brightness the engine is allowed to command. This prevents bulbs from flickering at ultra-low levels or getting "too bright" for specific zones.
5. Enhanced Real-Time Dashboard
The Live Circadian Dashboard has been upgraded to provide a unified view of your lighting's "Target State." It now displays:
  • Calculated Dimmer Level: Live view of the current target percentage.
  • Output Routing Status: Instant verification of which Virtual Dimmers or Hub Variables are currently being managed by the engine.
  • Solar Phase Context: Visual confirmation of where you are in the morning ramp, afternoon decay, or nighttime lock phases.
6. Dynamic Storm-Aware Dimming
The Daytime Storm Compensation feature now applies to the dimming engine as well. If your outdoor Lux sensor detects a heavy storm during the day, the engine won't just warm the lights; it will instantly drop the brightness to your "Cozy" setpoint until the weather clears.
App:
I primarily just wanted to thank you for this--it's exactly what I needed and worked great! I did have one issue that didn't work the way I expected, which may very well be a problem with my expectations, and it isn't something I can't work around (I already have). But I wanted to share that and one (description text) bug I found in your app, in case you're looking for feedback!
As for the "bugs" I found:
  1. Your link doesn't work in your first post. Looks like it's missing some underscores. Second link works.
  2. Sorry--not on my system right now, so I can't tell you exactly what line it is in your code, but in the "what it does" text for the "Circadian Boundaries & Curves" section, it says "Also allows you to invert the dimming logic so lights get dimmer as the evening approaches." --My understanding is, getting dimmer as evening approaches is the standard logic. Inverted logic is getting brighter, right? It doesn't affect the way the app works, I just noticed it and thought you might like the feedback.
  3. This is the one where it didn't work as I expected. I noticed that if you set the minimum brightness to 0, it pegs the calculated dimmer value to 10. If I set it to 1, it goes down to 1. If I set it to 3, it goes down to 3. --But if I set it to zero, it goes to 10. The reason I wanted to set mine to zero is so that, in the evening and night modes (and part of some mornings part of the year), when I have room lighting set the dim via the system variable, it simply won't turn the light on when it's triggered.
My use case for this app (and again, it's AWESOME, thank you!) is: I have created a faux window in my master bathroom (a 24x48" flat light panel behind plantation shutters), and I am using your app to drive the color temp and dimming of the light to mirror real world conditions to sell the illusion that it's a real window (it's VERY convincing) and allow it to be hands-off for scheduling that seasonally. Thing is, when it's dark outside, I simply don't want any light at all in that window. So really, the ability for this automation to turn the light completely off would be ideal. In my case, going down to 1 isn't enough, and going down to 0 makes the dimmer 10, which is very bright on this light.
Again, I'll say maybe my expectation is dumb here, but I thought it couldn't hurt to share my use case as a consideration in any further development. As a workaround, I've set up a rule to change the light temp and dimming every time the CT variable changes, but only between sunrise and sunset, and only if the light is "on." Then, room lighting only has to turn the light on and off based on motion in the bedroom and bathroom between sunrise and sunset. When room lighting turns it off because there's no one around, if it's after sunset, it stops turning the light on again, so it stays off until sunrise no matter what, and my rule machine rule won't trigger it. I THINK that if your app could return a zero value for dimming, I wouldn't need a separate rule to handle this. Anyway, it works great how I have it set up. Thanks for the contribution!
Ricky
I appreciate the feedback. I would actually love to see your fake window and how it functions using the application! This sounds incredible.
As far as fixing the logic to allow it to go to a minimum brightness of 0. I'll work on getting this change in place.
As for the rotation of how the application works on dimming. The idea is normal case the darker it gets the dimmer the bulbs, but if someone inverses this it allows the lights to get brighter to offset how dark it is outside.
