Release 2.2.4 Available
Release 2.2.4.156 Available
Changes from 2.2.4.153
  • Possible fix for stuck version update (from any earlier version).
  • Simple Automation Rule: cancelling anti-action fix.
  • Mode Manager: midnight handler fix.
  • Motion Lightning: option conflict fix.
  • Rule-4.0: Added Stop button.
  • C7: more mesh friendly z-wave startup.
  • Tasmota driver hub mesh fix
  • Rule Machine: tilde (~) is now a reserved character for Global Variable names. If you have any GV with a tilde in the name, these will have to be removed and renamed before you upgrade to 2.2.4.156. If you have already upgraded, you should roll back to fix these GVs. Ideally, this special character issue will be done away with in the next release (2.2.5). If you have such a GV, you can continue to use it. This issue affects deleting the GV, setting its value in the RM UI, and creating or removing a Connector for it.
** Please note that a hub reboot may be required after update - Settings >> Hub Reboot **
