I recently bought my third hubitat for my office and went through the setup process as usual.
Strange thing is, when i log in "my account" (or in the app) the new hub is named "my new hub".
But I renamed it already and when i´m logged in locally over the browser on the top right it shows the correct name. What could i have done wrong?
Should i simply un- and re-register the hub or is this a bad idea?
My new hub is the default name when a hub is first discovered. Make sure that the hub is still connected to the cloud. If it is, the name you set up locally will be updated. Showing the default name just means that your new name didn't sync with the cloud.
