*** UPDATE 10/7/2025 ***
The latest update fixed everything. Adding driver code no longer gives errors and new devices are no longer creating ghost items.
*** UPDATE 10/2/2025 ***
Hubitat says this is a known issue and will be fixed in the next update.
(Current version is 2.4.3.127.)
*** ORIGINAL POST***
C8-Pro.
Platform 2.4.2.134.
Newly purchased Oct 2024.
I started having issues installing new drivers some months back. I tried many things including uninstalling and reinstalling the Package Manager. Removing newer drivers. Searching for updates and waiting to see if updates would fix it. It's not just one driver and included issues with existing drivers not updating in the package manager.
My worry, based on the errors I'm getting trying to manually install drivers (see below), is the HUB might have files or a database that didn't update correctly or became corrupted.
The package manager errors out with the following when installing new packages:
Error Occurred During Installation
An error occurred while installing the package: Failed to install driver...
If I try to install a driver manually I get the following message:
org.h2.jdbc.JdbcSQLSyntaxErrorException: Column "ZW_DEVICE_CLASS" not found; SQL statement: INSERT INTO fingerprint (device_type_id, profile_id, endpoint_id, in_clusters, out_clusters, manufacturer, model, device_join_name, device_id, mfr, prod, controller_type, zw_device_class) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) [42122-224]
Packages and drivers that were in place prior to this starting continue to function. I just can't add new ones or update some old ones. I have been able to use generic drivers for some devices instead.
Secondarily, maybe related, but maybe not:
I was trying to install a new Z-WAVE device yesterday (first in a long while) and it wouldn't initiate and the only log message I found was "Z-Wave Inclusion timed out, status:7". I also have some devices that stop functioning randomly over time until I do a HUB reboot. Some of these devices are Z-WAVE and some are ZIGBEE.
Anyone see the above driver installation issues before?
Any tools exist that validate a Hub's database and system files?
Are there good instruction for doing a backup, factory reset to reinstall all HUBITAT, and a restore so I don't have to start from scratch?
Any other thoughts or ideas?
