Recommended Hub Temperature Range?
Is there a minimum/maximum "ambient" temperature that is recommended/required for the hub to operate?
I ask this because I'm debating on permanently placing each of my 3 hubs within 5 feet of 3 of my Schlage locks to "hopefully" make them stable/reliable, my concern is that one of my locks is on an outside shed and it is not climate controlled therefore it would be subject to outside temperature ranges of winter/summer.
I would ask Goldilocks. She appears to have a system. :wink:
What is the temperature range for the area of the world you live in?
0-110
Yeah, I wouldn't run the hub in that non-temp controlled outbuilding. Because if the outside temp is 110 the temp in a shed is going to reach upwards of 130 or higher.
