Last night I wrapped up my work desk overhaul and I was thinking a light in the style of a Hue Play would be a great addition to light up behind my monitors.
But some sticker shock on the $130 needed to make that happen.
The timing of this is fantastic, as I need the same thing as I tend to work when it's super early and super late (dark out) and am on Video call often where the shadows on my face are less than ideal.
I'm circling back around to the Hue Play again, $60 for a single one:
It doesn't include the power supply, but I do have an extra one in a bin somewhere.
I don't have anywhere behind to mount a lamp, besides that becomes less cost effective when one takes into account the $25 for a Sengled bulb + the cost of lamp
Someone linked a tower light using an LED strip on here one day. A corner light made of pvc, but you couldn't tell it was pvc or something rigid.
I want to try this in my home somewhere. I just think it's cool.
Love the cat in the window, BTW.
I did something similar. I went with LED strips on the back of the monitor as I wasn't competing with a window behind the monitor but I think you would be ok. I also went with a straight 6500K white led strip as this is the recommended 'bias' lighting to make colors pop on your screen as well as reduce eye fatigue in darker environments. These lights were only $30 or so on Amazon. Powered by USB and I have a ton of USB AC adapters around the house. You could put the LEDs a few inches in from the edges of your monitor and be fine I'm sure.
I have mine hooked into a smart plug. Then using @stephack 's 'Boot Me Up Scotty' App and a Samsung Smartthings multi-purpose sensor, when I pull my chair out, the led strips on the back of the monitor turn on and the computer comes out of sleep mode. When the multi-purpose sensor is inactive for 20 minutes, the lights turn off.
I ended up caving in and buying a Hue Play. Got it in yesterday, whipped up a piece of ABS to mount it on the monitor stand arm pointing it up and at the back wall
I'll definitely dig this for those late nights coding sessions
