Hello everyone, I recently bought a HE and I'm planning to use it to set it up to manage the climate in the home. I live in a ~720sqft apartment in Arlington, VA, and have four areas in the home I'd like to control: bedroom, living+dining room, den, and washroom.
Initially, I had thought of getting an Ecobee thermostat with its temperature/motion sensors and door/window sensors, together with Flair's smart vents. But as I researched further in this forum and on other places, it seems like there are better alternatives, going by: ability to work without Internet (ZigBee/Z-Wave), more direct control (vs a black box by the manufacturer), and lower price.
Here are my questions:
I am considering between the two highly recommended thermostats: Zen and Honeywell T6. From what I have found on the forum so far, it seems that both work equally well. Are there any specific quirks I should note?
Because my original plan was to use Ecobee's sensors for temperature, motion, and door/window detection, without that thermostat I'd need recommendations for alternatives. It would be good if they run on ZigBee or Z-Wave, though currently I'm using ZigBee for everything lighting-related.
(I actually own two AirThings View Pluses but I understand that they are not presently supported by HE and need the Internet to retrieve data.)
The biggest question I have is whether there are smart vents that work well with HE and/or the two aforementioned thermostats. The original plan was to use Flair with Ecobee, but without Ecobee, this is up in the air. I heard that Keen's products despite some quirks is still the best recommendation since it works without the Internet. Is this still the best practice?
Are there any other things I should note in setting this up? I'm new to all these so any advice will be greatly appreciated.
