I was hoping to get some suggestions on options for energy monitoring on my basement sump pump. I already have a leak sensor set up in the sump pit, but I'd like to also monitor when it's running. I realize a smart outlet is a simple option, but I don't need to have on/off control. In fact I worry that might be a failure point. I don't want to inadvertently turn power off on my sump pump!
One the latest firmwares for the Zooz Appliance switch (one of the few motor rated plug in modules) can disable both the physical and Zwave switches. (firmware 1.03 according to their documentation, see below) They are fairly economical, especially when they go on sale, which they regularly do (and are now).
https://www.support.getzooz.com/kb/article/309-zen15 power-switch-change-log/
From this document:
Added options to disable manual control and on/off commands from the hub
second that switch.. that is why i use for both a window ac unit and my basement dehumidifier.
if you prefer amazon to smartest house
https://www.amazon.com/gp/product/B07578W7KY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Thanks folks, I looked at the Zooz ZEN15 and think it's worth a try, especially at that price.
I just might buy one and find a use for it later!
