Received request from app that doesn't exist
Just started seeing this on my C8. Not sure why, I haven't changed anything recently besides updating to the most recent version. Any ideas?
That might be the Hubitat mobile app, judging only by the endpoint name (though it is fairly generic and could be any app that also uses this name). Try something like signing out of and back into the Hubitat mobile app, re-selecting your hub, or even uninstalling and reinstalling the app --on any device you might have at home when the local error appears or anywhere when the cloud error appears -- to see if that helps.
The update should not have affected this, so it's likely coincidental, but you can always try a downgrade via the Diagnostic Tool if you suspect something.
Looks like it is coming from the mobile app. Logs show the error every time I open it. I'll try uninstalling/reinstalling
Looks like an uninstall/reinstall helped suppress the error.
Another thing to note- I had uninstalled dashboards a long time ago and just reinstalled it to troubleshoot this issue. The dashboard tab in the app remains blank, even though there are dashboards created. Maybe this has something to do with the issue?
I suspect that is the endpoint that tries to retrieve the list of Dashboards, so that's probably it! I'd expect signing out and back in or re-selecting your hub (and then this mobile app device) would fix that, but maybe it's hanging on to something else somewhere if not...
