This is probably the wrong place for this, but here goes.
I have some MHCozy single channel switches, and note some seem more reliable then others.
Opening some of them up, I see an antenna shaped like a coil just hanging into space.
You see it here, the black coil at a 45 degeree angle.
In each of the devices, the orientation of the antenna, at least, is different. I suspect the length of the wire, and tightness of the coil and diameter is different also.
It occurs to me the variable dimensions of that antenna may make a big difference in the connectivity of the device to the hub.
I know, for example, that antennas do not work well along the axis of the coil, rather preferred is to have the other radio off to the side of the coil.
My question, does anybody know if a simple way (of course "simple" when dealing with antennas is relative) to change the shape, and maybe length of the wire to optimize reception.
I bet getting support from the manufacturer on this topic to diagnose at the Cozy end will be difficult, but maybe using Hubitat or another hub may work.
Does Hubitat have a signal strength variable for each device? I haven't seen one.
I suspect the diagnostic machine would have to be pretty sophisticated with the device ID and signal strength at a minimum.
I'm sure the manufacturers just pump these antennas out and they probably have a fairly wide tolerance.
Thanks, Mark.
