Where "Backyard" is my backyard Ring cam.
And zAlexaBackyardMotion is my momentary virtual switch that hits the ifttt/ring app end point.
The simple action of "power on" will do the right thing where it will turn on/off appropriately in line with the motion.
Edit: Also tip for setting up the momentary switch, make sure you get your Hubitate IP address right and include the device port of 8080 since it's an internal call. Without that it fails which took me a long time to figure out.
Awesome. Thank you for the help. I've been having lots of issues lately with IFTTT so I'm going to try your route. I figure since Amazon owns Ring, this might be a better way to go anyway.
After much searching, I've come to the conclusion that there isn't anything which will easily integrate with Hubitat when it comes to monitored alarm systems. I opted to go with Scout Alarm, because they're reasonably priced, independent and have certified monitoring services. They have a number of other integrations (IFTTT, SmartThings, Google Home, Alexa to name a few off the top of my head) and when I reached out to their support they said they would be open to exploring a Hubitat integration if it was requested enough, I think they would also want the Hubitat team to help integrate it as well.
A LOT of solid work was put into the unofficial Ring integration and, thus far, it's worked like a charm. Not been too hard and is a cornerstone of what I have going on right now.
(I do agree, "official" integration would be great).
Still, the number of companies I would trust to do monitoring isn't particularly large.
Agreed, this integration has been exactly what I've needed. Being able to trigger on/off the alarm and see the ring connected sensors as native sensors in HE has been hands-down fantastic.
One thing I've noticed is that the my ring doorbell 2 cam seems to go to sleep, this ends up giving a blank live feed to my dash (until something wakes it up) and I get lots of the following in my logs. When the cam is running things are fine. Any suggestions?
Just had a fun brainstorm for a new Hubitat-Ring feature:
The ability to send text-to-speech (TTS) commands or MP3 audio to sound-enabled devices (like the Ring Camera series, with exterior speakers). So that when motion is detected, for example, the camera could be made to say, "I see you there!"
You might not want to do this, if the purpose of the virtual switch is just to provide a way for an Alexa routine to trigger something on HE.
I give those virtual switches names that Alexa would likely never mistake anyone actually saying, so they can't be activated except via Alexa routines.
I have a working HE integration with QolSys IQ2+ alarm panels. Doesn't rely on web scraping or anything like that, it connects directly to a local endpoint on the panel.
Only problem is that HE doesn't provide a way to create an encrypted socket connection, so it's a bit complicated to set up. I'm using NodeRed, openssl and mqtt to make the connection between the panel and HE. If/when HE ever adds an encrypted socket, I'll simplify the drivers and publish them.
Not sure about "both", but "Get Ding" is a way to poll for motion status.
When you setup this integration, there is an option to poll (not recommended) v.s. using push through IFTTT (or some of us are using Alexa instead).
A "Ding" in this integration is another way to define "motion" or "ring".
I'm having an issue where I added two new devices to my Ring network and it's not showing up in Hubitat. Is there a manual way I can trigger (re-)discovery of devices? In my case, I am trying to add a steplight and a motion sensor. Any help greatly appreciated!
There is no reaction at all. I have turned on debug logging:
createDevices(984d9851-7ee8-4b55-5800-ab9d93c308af)
debugAttempting to create devices.
The Ring Motion Sensor I recently purchased isn't showing up in the list. With "trace logging" enabled, I see a little more, but again, outcome is the same.
debugWatchdog checking started. Time since last check: 0.0 minutes
debugsimpleRequest(refresh)
infoRefreshing hub 4e484cd9-4238-4b84-8261-0454d531261b with kind base_station_v1
debugrefresh(4e484cd9-4238-4b84-8261-0454d531261b)
debugcreateDevices(4e484cd9-4238-4b84-8261-0454d531261b)
Thank you for any help you might be able to provide.
