Behaves strange, as I already mentioned... I want to first finish the driver for it as I have already spent time, then will crack open it to see what is inside. I may end up satisfying my curiosity at a high price ...
An interesting 24 GHz radar appeared on AliExpress, unfortunately, only WiFi / BT versions at the moment. Usually, the Zigbee versions follow several months later.
I'm interested in this product, so I put it in the cart.
When I saw your explanation, I mistook it for this product at first.
This 24 uses the frequency band in the middle of the existing Toya product 5.8 and Fp1 60.
I wonder if there is a plan to use Wi-Fi and it locally on Hubitat.
The product you are describing seems to use the same app as the sensor you have. Then there is a possibility that sensing is not immediate. A little bit of delay...
