Loving the easy dashboards!
I just can't figure out
How to change the icon of devices?
Icons seem to be set based on type of device. I have a zigbee plug that is connected to a fan and I want the icon to represent a fan instead of an outlet.
How do I generate local LAN links? It seems cloud link is the default only option now (?)
This is not the same as the previous LAN link because this one requires the user to LOG IN which is a problem for me. I need a local link with the access key embedded already and allow use w/o login.
Considering that it's been less than a day and you asked over a weekend, I might wait until Monday to expect a staff response. They'd probably be the ones to know. But off hand, I don't see a way to do exactly that with a local URL.
I'd also like to know if there's a way to create a LAN link that allows access without login and also to create an associated QR code. I do this with the original dashboard functionality to create a guest dashboard.
