I could use some help on,
how to set manufacturer & model fingerprint for a LAN device.
I built a driver for a local LAN device and I want to set the fingerprint data so it shows in Maker-API.
If possible??
If possible??
There is no fingerprint for lan devices because they cannot be auto-discovered. They can only be added manually or by an app. So, there is no point in having a fingerprint.
The maker API does not display any fingerprint data. What specific field are you referring to?
The fingerprint is used by the system to be able to identify which driver should be used when a zigbee or z-wave device is added to the system.
