I have had a request from someone, and perhaps someone here can give me some advice.
Is it possible to setup a house with 20-50 Shelly devices (controlled by Hubitat)?
Will I overload the router? (a Asus AiMesh system)
Does anyone here run such a system? How many devices?
Do the Shelly devices fit easily into a switch box, or is it difficult to fit it in?
Anyone with experience on a lot of Shelly devices.
Thank you in advance.
I'm using round about 50 Shelly (and other) WIFI devices.
My router (FRITZ!Box 7490) has no problem handling all this.
The Shelly devices can fit easily into a switch box - but of course it depends: Is your installation using flat, normal (ca. 60 mm), or deep in-wall sockets? Is the installed manual switch flat or thick?
=> Maybe you should look at the specifications of the Shelly devices to ensure that you have enough room.
I have several Shelly modules and they work perfectly... with one caveat, specifically with the Dimmer2 module.
When connected directly to a momentary switch it does dim until the momentary switch is released. From Hubitat, the dimmer module accepts on, off, and dim to "x" level commands. It doesn't recognise start/stop dimming commands. This only becomes a problem if you intend to use the hold/release function on a scene switch or button to "dim until released."
My switches are all surface mounted & I needed deeper pattress boxes but compared with all the other modules I own, Shelly's are among the smallest.
